I custom made a PB and bela mini and embedded it on a PCB with other components and works great! Before I embedded it I was programming with an FTDI cable till I got wifi up, then programmed over ssh. Now I want to program through the FTDI cable again because Im going to testing what will happen if my system loses wifi, but it doesn't seem to be working.
I see the start up showing U-Boot, it says starting kernel but always stops after two commands:
[ 0.002144] clocksource_probe: no matching clocksources found
[ 0.853782] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
I try sshing into it and it works fine there. Is there anything else I should be checking to make sure I can program over FTDI?
