hi there,
recently i have not been able to compile my heavy patches anymore when compiling from the IDE. i get a ton of warnings about unused private fields and then it simply stops compiling. also i get a "too many messages printed to console". from an ssh session i can compile just fine, i get the same warnings, but the compiler does still succeed. so it seems the IDE struggles and takes the whole compilation down...
this is the warnings output, just the last lines... (from ssh not IDE, but they are the same):
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5536:16: warning: private field 'cBinop_P5DJPnTc' is not used [-Wunused-private-field]
ControlBinop cBinop_P5DJPnTc;
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5540:16: warning: private field 'cBinop_qJtXJfZ9' is not used [-Wunused-private-field]
ControlBinop cBinop_qJtXJfZ9;
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5542:16: warning: private field 'cBinop_kgxR5g2D' is not used [-Wunused-private-field]
ControlBinop cBinop_kgxR5g2D;
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5557:16: warning: private field 'cBinop_lZclhfjC' is not used [-Wunused-private-field]
ControlBinop cBinop_lZclhfjC;
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5563:16: warning: private field 'cBinop_sACf3rCt' is not used [-Wunused-private-field]
ControlBinop cBinop_sACf3rCt;
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5566:16: warning: private field 'cBinop_u7MXjsgz' is not used [-Wunused-private-field]
ControlBinop cBinop_u7MXjsgz;
/root/Bela/projects/voxheavypresets/Heavy_bela.hpp:5568:16: warning: private field 'cBinop_WnDfiEb5' is not used [-Wunused-private-field]
ControlBinop cBinop_WnDfiEb5;
683 warnings generated.
