thanks to dywen I managed to replace the render.cpp file
giuliomoro .
It seems to be working fine with block sizes included between 32 and 128 :
Ihv_noteout: 0xd1d4ac2
hv_ctlout: 0xe5e2a040
hv_pgmout: 0x8753e39e
hv_touchout: 0x476d4387
hv_polytouchout: 0xd5aca9d1
hv_bendout: 0xe8458013
__hv_midiout: 0x6511de55
: 0
Starting Heavy context with 23 input channels and 24 output channels
Channels in use:
Digital in : 13, Digital out: 14
Scope out: 0
Failed to open MIDI device hw:1,0,0
No MIDI device enabled
Bela digital: channel 4 is set as input at signal rate
Bela digital: channel 5 is set as input at signal rate
Bela digital: channel 8 is set as input at signal rate
Bela digital: channel 9 is set as input at signal rate
Bela digital: channel 0 is set as output at signal rate
Bela digital: channel 1 is set as output at signal rate
Bela digital: channel 2 is set as output at signal rate
Bela digital: channel 3 is set as output at signal rate
Bela digital: channel 7 is set as output at signal rate
Bela digital: channel 6 is set as output at signal rate
Bela digital: channel 12 is set as input at signal rate
Bela digital: channel 13 is set as output at signal rate
1 mode switch detected on the audio thread.
No more audio switch afterward.
However from 512 to upper :
Build finished
Running project ...
: 0
Bus error
make: *** [runide] Error 135
Makefile:579: recipe for target 'runide' failed
Bela stopped
I'm rather interested by the lowest latency possible so that does not bother me apparently...
