Hi Giulio/all,
got my Pepper working. I will use it in my Eurorack setup. I would like to be sure of what I'm doing with the power before doing something stupid. I have few questions therefore:
1- I can use the Eurorack ribbon cable to power it, is it enough or should I still need to take that 5V power out from the eurorack and plug into the barrel jack?
2- Is there a position on the board to add that regulator or should I fix it on a separate board? Any image of somebody that did that just to follow?
3- What is the best jumper position? I assume "with regulator", "10V"
Thanks
