just got this:
PRU interrupt timeout, -1 110 Connection timed outPRU interrupt timeout, -1 110 Connection timed outPRU interrupt timeout, -1 110 Connection timed outPRU interrupt timeout, -1 110 Connection timed outThe PRU stopped responding. Is the light still blinking? It would be very helpful if you could send the output of the `dmesg` command to the developers to help track down the issue. Quitting.PRU interrupt timeout, -1 110 Connection timed outMakefile:524: recipe for target 'runide' failedmake: *** [runide] Error 1Bela stopped
and yes, the light is still blinking. here is the dmesg:
on Tue 23 Oct 13:25:56 BST 2018
root@bela:~# python2.7 ~/hvcc/hvcc.py Bela/projects/voxpresets/_main.pd -o /tmp/hvtmp -n bela -g c
__log2~f requires perf information.
__cos~f requires perf information.
__sqrt~f requires perf information.
1) Warning pd2hv: _main.pd in "_main.pd" @ (x:0, y:0): [rzero~] accepts only signal input. Arguments and control connections are ignored.
root@bela:~# rsync -av /root/Bela/projects/voxpresets/render.cpp /tmp/hvtmp/c/* /root/Bela/projects/voxheavypresets/
sending incremental file list
Heavy_bela.cpp
Heavy_bela.h
Heavy_bela.hpp
render.cpp
sent 924,750 bytes received 92 bytes 1,849,684.00 bytes/sec
total size is 1,181,271 speedup is 1.28
root@bela:~# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.113-ti-xenomai-r149 (root@giulio-VirtualBox) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #1 PREEMPT Wed Sep 26 15:40:33 BST 2018
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c100bb04, node_mem_map dfb79000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[ 0.000000] Memory: 501008K/524288K available (11518K kernel code, 872K rwdata, 3656K rodata, 456K init, 967K bss, 23280K reserved, 0K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0ed9b68 (15175 kB)
.init : 0xc0eda000 - 0xc0f4c000 ( 456 kB)
.data : 0xc0f4c000 - 0xc10260bc ( 873 kB)
.bss : 0xc1029000 - 0xc111ae04 ( 968 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000041] I-pipe, 24.000 MHz clocksource, wrap in 178956 ms
[ 0.000063] clocksource: ipipe_tsc: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000089] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000100] OMAP clocksource: timer1 at 24000000 Hz
[ 0.001148] clocksource_probe: no matching clocksources found
[ 0.001711] Interrupt pipeline (release #9)
[ 0.001916] Console: colour dummy device 80x30
[ 0.001962] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.046228] pid_max: default: 32768 minimum: 301
[ 0.046380] Security Framework initialized
[ 0.046394] Yama: becoming mindful.
[ 0.046437] AppArmor: AppArmor disabled by boot time parameter
[ 0.046487] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.046501] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047393] Initializing cgroup subsys io
[ 0.047429] Initializing cgroup subsys memory
[ 0.047484] Initializing cgroup subsys devices
[ 0.047503] Initializing cgroup subsys freezer
[ 0.047522] Initializing cgroup subsys net_cls
[ 0.047539] Initializing cgroup subsys perf_event
[ 0.047557] Initializing cgroup subsys net_prio
[ 0.047580] Initializing cgroup subsys pids
[ 0.047641] CPU: Testing write buffer coherency: ok
[ 0.048170] Setting up static identity map for 0x80008200 - 0x80008260
[ 0.053677] devtmpfs: initialized
[ 0.083746] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.127528] omap_hwmod: debugss: _wait_target_disable failed
[ 0.169376] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.169413] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.170037] xor: measuring software checksum speed
[ 0.206259] arm4regs : 1146.000 MB/sec
[ 0.246215] 8regs : 908.000 MB/sec
[ 0.286215] 32regs : 1031.000 MB/sec
[ 0.326217] neon : 1377.000 MB/sec
[ 0.326228] xor: using function: neon (1377.000 MB/sec)
[ 0.326279] pinctrl core: initialized pinctrl subsystem
[ 0.328575] NET: Registered protocol family 16
[ 0.330352] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.339696] OMAP GPIO hardware version 0.1
[ 0.357158] No ATAGs?
[ 0.357199] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.450275] raid6: neonx2 gen() 1849 MB/s
[ 0.518230] raid6: neonx2 xor() 1137 MB/s
[ 0.518243] raid6: using algorithm neonx2 gen() 1849 MB/s
[ 0.518253] raid6: .... xor() 1137 MB/s, rmw enabled
[ 0.518262] raid6: using intx1 recovery algorithm
[ 0.530732] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.537865] SCSI subsystem initialized
[ 0.538410] libata version 3.00 loaded.
[ 0.538830] usbcore: registered new interface driver usbfs
[ 0.538934] usbcore: registered new interface driver hub
[ 0.539060] usbcore: registered new device driver usb
[ 0.539881] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.539948] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.541671] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.541988] media: Linux media interface: v0.10
[ 0.542075] Linux video capture interface: v2.00
[ 0.542207] pps_core: LinuxPPS API ver. 1 registered
[ 0.542291] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.542337] PTP clock support registered
[ 0.543483] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.545093] NetLabel: Initializing
[ 0.545116] NetLabel: domain hash size = 128
[ 0.545124] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.545218] NetLabel: unlabeled traffic allowed by default
[ 0.545633] clocksource: Switched to clocksource ipipe_tsc
[ 0.712405] NET: Registered protocol family 2
[ 0.713359] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.713411] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.713453] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.713543] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.713566] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.713927] NET: Registered protocol family 1
[ 0.714612] RPC: Registered named UNIX socket transport module.
[ 0.714631] RPC: Registered udp transport module.
[ 0.714640] RPC: Registered tcp transport module.
[ 0.714649] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.715708] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.719183] audit: initializing netlink subsys (disabled)
[ 0.719291] audit: type=2000 audit(0.716:1): initialized
[ 0.720248] [Xenomai] scheduling class idle registered.
[ 0.720265] [Xenomai] scheduling class rt registered.
[ 0.720437] I-pipe: head domain Xenomai registered.
[ 0.729809] [Xenomai] Cobalt v3.0.6 (Stellar Parallax) [DEBUG]
[ 0.742475] zbud: loaded
[ 0.743283] VFS: Disk quotas dquot_6.6.0
[ 0.743599] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.747196] NFS: Registering the id_resolver key type
[ 0.747284] Key type id_resolver registered
[ 0.747295] Key type id_legacy registered
[ 0.747330] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.747780] fuse init (API version 7.23)
[ 0.748631] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 0.759928] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.760257] io scheduler noop registered
[ 0.760280] io scheduler deadline registered
[ 0.760367] io scheduler cfq registered (default)
[ 0.762455] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.763530] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0
[ 0.763744] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1
[ 0.763760] gpio-of-helper ocp:cape-universal: ready
[ 0.765485] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.767875] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.772066] console [ttyS0] disabled
[ 0.772179] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.785579] console [ttyS0] enabled
[ 0.787606] [drm] Initialized drm 1.1.0 20060810
[ 0.789524] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.790086] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.790426] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.790741] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.845688] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 0.845718] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 0.846320] davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 0.847752] libphy: 4a101000.mdio: probed
[ 0.847785] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.848690] cpsw 4a100000.ethernet: Detected MACID = 40:bd:32:e0:d9:3b
[ 0.848866] cpsw 4a100000.ethernet: cpts: overflow check period 2125
[ 0.851317] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.851395] ehci-platform: EHCI generic platform driver
[ 0.851695] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.852330] usbcore: registered new interface driver usb-storage
[ 0.855331] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.858534] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.858562] musb-hdrc: MHDRC RTL version 2.0
[ 0.858574] musb-hdrc: setup fifo_mode 4
[ 0.858603] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.860674] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 0.863624] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.863652] musb-hdrc: MHDRC RTL version 2.0
[ 0.863663] musb-hdrc: setup fifo_mode 4
[ 0.863689] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.863858] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.863902] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.864265] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.864281] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.864294] usb usb1: Product: MUSB HDRC host driver
[ 0.864305] usb usb1: Manufacturer: Linux 4.4.113-ti-xenomai-r149 musb-hcd
[ 0.864317] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 0.865489] hub 1-0:1.0: USB hub found
[ 0.865567] hub 1-0:1.0: 1 port detected
[ 0.878033] mousedev: PS/2 mouse device common for all mice
[ 0.881201] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 0.882605] i2c /dev entries driver
[ 0.884901] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.886041] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.951844] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.952850] usbcore: registered new interface driver usbhid
[ 0.952866] usbhid: USB HID core driver
[ 0.953283] ashmem: initialized
[ 0.955507] remoteproc0: wkup_m3 is available
[ 0.955529] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 0.955541] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 0.967373] NET: Registered protocol family 10
[ 0.969162] mip6: Mobile IPv6
[ 0.969197] NET: Registered protocol family 17
[ 0.969367] Key type dns_resolver registered
[ 0.969389] mpls_gso: MPLS GSO support
[ 0.969879] omap_voltage_late_init: Voltage driver support not added
[ 0.977231] PM: Cannot get wkup_m3_ipc handle
[ 0.981887] ThumbEE CPU extension supported.
[ 0.983385] registered taskstats version 1
[ 0.983668] zswap: loaded using pool lzo/zbud
[ 0.988534] Btrfs loaded
[ 0.990982] Key type encrypted registered
[ 0.994631] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.995862] mmc1: MAN_BKOPS_EN bit is not set
[ 0.999617] mmc1: new high speed MMC card at address 0001
[ 1.000583] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.000974] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 1.001321] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 1.003145] mmcblk1: p1 p2
[ 1.021297] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.022132] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.022201] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.023880] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.025339] remoteproc0: powering up wkup_m3
[ 1.025374] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 1.025900] remoteproc0: remote processor wkup_m3 is now up
[ 1.025924] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 1.031346] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,00C0,2818BBBK0032'
[ 1.031386] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 1.069681] bone_capemgr bone_capemgr: slot #0: No cape found
[ 1.109668] bone_capemgr bone_capemgr: slot #1: No cape found
[ 1.149668] bone_capemgr bone_capemgr: slot #2: No cape found
[ 1.189708] bone_capemgr bone_capemgr: slot #3: No cape found
[ 1.189825] bone_capemgr bone_capemgr: initialized OK.
[ 1.190289] PM: bootloader does not support rtc-only!
[ 1.191452] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 1.191488] of_cfs_init
[ 1.191637] of_cfs_init: OK
[ 1.199732] PM: Hibernation image not present or could not be loaded.
[ 1.209978] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.210092] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.210997] devtmpfs: mounted
[ 1.211601] Freeing unused kernel memory: 456K
[ 1.401825] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[ 1.473511] systemd[1]: System time before build time, advancing clock.
[ 1.526958] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.531046] usb 1-1: New USB device found, idVendor=1f38, idProduct=001e
[ 1.531074] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.531086] usb 1-1: Product: QUNEO
[ 1.531097] usb 1-1: Manufacturer: KESUMO, LLC
[ 1.559099] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 1.562630] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 1.576229] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.577059] systemd[1]: Detected architecture arm.
[ 1.578425] systemd[1]: Set hostname to <bela>.
[ 1.779792] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 26 bits of entropy available)
[ 1.812283] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[ 1.855642] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 28 bits of entropy available)
[ 1.861981] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 28 bits of entropy available)
[ 1.932745] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[ 1.933056] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[ 1.933475] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[ 1.934637] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[ 2.186782] systemd[1]: Reached target Swap.
[ 2.189057] systemd[1]: Created slice User and Session Slice.
[ 2.189576] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.190534] systemd[1]: Listening on udev Control Socket.
[ 2.191027] systemd[1]: Listening on Syslog Socket.
[ 2.191238] systemd[1]: Reached target Remote File Systems.
[ 2.191608] systemd[1]: Listening on udev Kernel Socket.
[ 2.192431] systemd[1]: Listening on Journal Audit Socket.
[ 2.192882] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.193436] systemd[1]: Listening on Journal Socket.
[ 2.194476] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.196381] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.198413] systemd[1]: Created slice System Slice.
[ 2.199993] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.201071] systemd[1]: Reached target Slices.
[ 2.207149] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.221182] systemd[1]: Starting Load Kernel Modules...
[ 2.364544] systemd[1]: Mounting Debug File System...
[ 2.379741] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.381644] systemd[1]: Created slice system-getty.slice.
[ 2.399618] rtdm_pruss_irq: loading out-of-tree module taints kernel.
[ 2.400526] rtdm_pruss_irq version 1 loaded
[ 2.448949] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.547701] systemd[1]: Starting Journal Service...
[ 2.548510] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.658953] systemd[1]: Starting File System Check on Root Device...
[ 2.659734] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.660017] systemd[1]: Reached target Encrypted Volumes.
[ 2.660223] systemd[1]: Reached target Paths.
[ 2.785568] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.806248] systemd[1]: Mounted Debug File System.
[ 2.826857] systemd[1]: Started Load Kernel Modules.
[ 2.837446] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 2.910770] systemd[1]: Started File System Check Daemon to report status.
[ 2.964304] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 3.048453] systemd[1]: Mounting FUSE Control File System...
[ 3.204077] systemd[1]: Starting Apply Kernel Variables...
[ 3.344248] systemd[1]: Mounting Configuration File System...
[ 3.502889] systemd[1]: Mounted FUSE Control File System.
[ 3.505526] systemd[1]: Started File System Check on Root Device.
[ 3.559342] systemd[1]: Started Create Static Device Nodes in /dev.
[ 3.571864] systemd[1]: Started Apply Kernel Variables.
[ 3.573344] systemd[1]: Mounted Configuration File System.
[ 3.644134] systemd[1]: Starting udev Kernel Device Manager...
[ 3.694327] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.767288] systemd[1]: Started Journal Service.
[ 3.893154] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 4.326882] systemd-journald[111]: Received request to flush runtime journal from PID 1
[ 6.642312] usbcore: registered new interface driver snd-usb-audio
[ 6.703374] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 7.426719] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 7.613528] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 9.863363] random: nonblocking pool is initialized
[ 9.910054] using random self ethernet address
[ 9.910091] using random host ethernet address
[ 10.054099] using random self ethernet address
[ 10.054134] using random host ethernet address
[ 10.213843] Mass Storage Function, version: 2009/09/11
[ 10.213880] LUN: removable file: (no medium)
[ 12.103729] usb0: HOST MAC be:1a:32:e0:d9:3c
[ 12.104235] usb0: MAC be:1a:32:e0:d9:3d
[ 12.107632] usb1: HOST MAC be:1a:32:e0:d9:3f
[ 12.107988] usb1: MAC be:1a:32:e0:d9:40
[ 13.270062] net eth0: initializing cpsw version 1.12 (0)
[ 13.270098] net eth0: initialized cpsw ale version 1.4
[ 13.270111] net eth0: ALE Table size 1024
[ 13.272710] net eth0: phy found : id is : 0x7c0f1
[ 13.317192] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.797464] configfs-gadget gadget: high-speed config #1: c
[ 20.708537] rtdm_pruss_irq_open
[ 20.708915] Registering PRU interrupt:
PRU ICSS system event: 20
PRU INTC channel: 4
PRU INTC host interrupt: 4
ARM IRQ number: 22
[ 20.708941] rtdm_pruss_irq linux_irq: 180 for arm_irq_handle_number: 22
[ 20.708950] INITING_PRU: system_event: 20, intc_channel: 4, intc_host: 4
[ 20.708958] : 0XD00 = 0XFFFFFFFF [u32]
[ 20.708966] : 0XD04 = 0XFFFFFFFF [u32]
[ 20.708973] : 0XD80 = 0X0 [u32]
[ 20.708981] : 0XD84 = 0X0 [u32]
[ 20.708989] cmr_reg
[ 20.708997] : 0X414 = 0X4 [u8]
[ 20.709005] hmr_reg
[ 20.709011] : 0X804 = 0X4 [u8]
[ 20.709018] secr0
[ 20.709024] : 0X280 = 0XFFFFFFFF [u32]
[ 20.709032] secr1
[ 20.709038] : 0X284 = 0XFFFFFFF [u32]
[ 20.709045] eisr_reg
[ 20.709051] : 0X28 = 0X14 [u32]
[ 20.709058] hieisr_reg
[ 20.709064] : 0X34 = 0X4 [u32]
[ 20.709072] hier
[ 20.709078] hier read: 10
[ 20.709084] esr0
[ 20.709091] : 0X300 = 0X100000 [u32]
[ 20.709098] intc_ger
[ 20.709104] : 0X10 = 0X1 [u32]
[ 332.542845] rtdm_pruss_irq_close
[ 332.542887] rtdm_irq_free
[ 332.542901] rtdm_event_pulse
[ 332.542911] rtdm_event_destroy
[ 336.813308] rtdm_pruss_irq_open
[ 336.813738] Registering PRU interrupt:
PRU INTC channel: 4
ARM IRQ number: 22
[ 336.813762] rtdm_pruss_irq linux_irq: 180 for arm_irq_handle_number: 22
[ 336.813772] INITING_PRU: system_event: 20, intc_channel: 4, intc_host: 4
[ 336.813780] : 0XD00 = 0XFFFFFFFF [u32]
[ 336.813787] : 0XD04 = 0XFFFFFFFF [u32]
[ 336.813795] : 0XD80 = 0X0 [u32]
[ 336.813802] : 0XD84 = 0X0 [u32]
[ 336.813810] cmr_reg
[ 336.813820] : 0X414 = 0X4 [u8]
[ 336.813827] hmr_reg
[ 336.813833] : 0X804 = 0X4 [u8]
[ 336.813840] secr0
[ 336.813846] : 0X280 = 0XFFFFFFFF [u32]
[ 336.813853] secr1
[ 336.813860] : 0X284 = 0XFFFFFFF [u32]
[ 336.813867] eisr_reg
[ 336.813873] : 0X28 = 0X14 [u32]
[ 336.813880] hieisr_reg
[ 336.813886] : 0X34 = 0X4 [u32]
[ 336.813893] hier
[ 336.813899] hier read: 10
[ 336.813906] esr0
[ 336.813912] : 0X300 = 0X100000 [u32]
[ 336.813920] intc_ger
[ 336.813926] : 0X10 = 0X1 [u32]
[ 346.526473] rtdm_pruss_irq_close
[ 346.526515] rtdm_irq_free
[ 346.526528] rtdm_event_pulse
[ 346.526538] rtdm_event_destroy
[ 722.967968] rtdm_pruss_irq_open
[ 722.968336] Registering PRU interrupt:
PRU INTC channel: 4
ARM IRQ number: 22
[ 722.968362] rtdm_pruss_irq linux_irq: 180 for arm_irq_handle_number: 22
[ 722.968371] INITING_PRU: system_event: 20, intc_channel: 4, intc_host: 4
[ 722.968379] : 0XD00 = 0XFFFFFFFF [u32]
[ 722.968387] : 0XD04 = 0XFFFFFFFF [u32]
[ 722.968395] : 0XD80 = 0X0 [u32]
[ 722.968402] : 0XD84 = 0X0 [u32]
[ 722.968410] cmr_reg
[ 722.968419] : 0X414 = 0X4 [u8]
[ 722.968426] hmr_reg
[ 722.968432] : 0X804 = 0X4 [u8]
[ 722.968439] secr0
[ 722.968446] : 0X280 = 0XFFFFFFFF [u32]
[ 722.968453] secr1
[ 722.968459] : 0X284 = 0XFFFFFFF [u32]
[ 722.968466] eisr_reg
[ 722.968472] : 0X28 = 0X14 [u32]
[ 722.968479] hieisr_reg
[ 722.968485] : 0X34 = 0X4 [u32]
[ 722.968493] hier
[ 722.968499] hier read: 10
[ 722.968505] esr0
[ 722.968512] : 0X300 = 0X100000 [u32]
[ 722.968519] intc_ger
[ 722.968525] : 0X10 = 0X1 [u32]
[ 759.719807] rtdm_pruss_irq_close
[ 759.719841] rtdm_irq_free
[ 759.719854] rtdm_event_pulse
[ 759.719864] rtdm_event_destroy
