just got this:
PRU interrupt timeout, -1 110 Connection timed outPRU interrupt timeout, -1 110 Connection timed outPRU interrupt timeout, -1 110 Connection timed outPRU interrupt timeout, -1 110 Connection timed outThe PRU stopped responding. Is the light still blinking? It would be very helpful if you could send the output of the `dmesg` command to the developers to help track down the issue. Quitting.PRU interrupt timeout, -1 110 Connection timed outMakefile:524: recipe for target 'runide' failedmake: *** [runide] Error 1Bela stopped
and yes, the light is still blinking. here is the dmesg:
on Tue 23 Oct 13:25:56 BST 2018
root@bela:~# python2.7 ~/hvcc/hvcc.py Bela/projects/voxpresets/_main.pd -o /tmp/hvtmp -n bela -g c
__log2~f requires perf information.
__cos~f requires perf information.
__sqrt~f requires perf information.
  1) Warning pd2hv: _main.pd in "_main.pd" @ (x:0, y:0): [rzero~] accepts only signal input. Arguments and control connections are ignored.
root@bela:~# rsync -av /root/Bela/projects/voxpresets/render.cpp  /tmp/hvtmp/c/* /root/Bela/projects/voxheavypresets/
sending incremental file list
Heavy_bela.cpp
Heavy_bela.h
Heavy_bela.hpp
render.cpp
sent 924,750 bytes  received 92 bytes  1,849,684.00 bytes/sec
total size is 1,181,271  speedup is 1.28
root@bela:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.113-ti-xenomai-r149 (root@giulio-VirtualBox) (gcc version 5.5.0 (Linaro GCC 5.5-2017.10) ) #1 PREEMPT Wed Sep 26 15:40:33 BST 2018
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 131072
[    0.000000] free_area_init_node: node 0, pgdat c100bb04, node_mem_map dfb79000
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 501008K/524288K available (11518K kernel code, 872K rwdata, 3656K rodata, 456K init, 967K bss, 23280K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
                   lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0ed9b68   (15175 kB)
                     .init : 0xc0eda000 - 0xc0f4c000   ( 456 kB)
                     .data : 0xc0f4c000 - 0xc10260bc   ( 873 kB)
                      .bss : 0xc1029000 - 0xc111ae04   ( 968 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000041] I-pipe, 24.000 MHz clocksource, wrap in 178956 ms
[    0.000063] clocksource: ipipe_tsc: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000089] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000100] OMAP clocksource: timer1 at 24000000 Hz
[    0.001148] clocksource_probe: no matching clocksources found
[    0.001711] Interrupt pipeline (release #9)
[    0.001916] Console: colour dummy device 80x30
[    0.001962] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[    0.046228] pid_max: default: 32768 minimum: 301
[    0.046380] Security Framework initialized
[    0.046394] Yama: becoming mindful.
[    0.046437] AppArmor: AppArmor disabled by boot time parameter
[    0.046487] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.046501] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.047393] Initializing cgroup subsys io
[    0.047429] Initializing cgroup subsys memory
[    0.047484] Initializing cgroup subsys devices
[    0.047503] Initializing cgroup subsys freezer
[    0.047522] Initializing cgroup subsys net_cls
[    0.047539] Initializing cgroup subsys perf_event
[    0.047557] Initializing cgroup subsys net_prio
[    0.047580] Initializing cgroup subsys pids
[    0.047641] CPU: Testing write buffer coherency: ok
[    0.048170] Setting up static identity map for 0x80008200 - 0x80008260
[    0.053677] devtmpfs: initialized
[    0.083746] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.127528] omap_hwmod: debugss: _wait_target_disable failed
[    0.169376] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.169413] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.170037] xor: measuring software checksum speed
[    0.206259]    arm4regs  :  1146.000 MB/sec
[    0.246215]    8regs     :   908.000 MB/sec
[    0.286215]    32regs    :  1031.000 MB/sec
[    0.326217]    neon      :  1377.000 MB/sec
[    0.326228] xor: using function: neon (1377.000 MB/sec)
[    0.326279] pinctrl core: initialized pinctrl subsystem
[    0.328575] NET: Registered protocol family 16
[    0.330352] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.339696] OMAP GPIO hardware version 0.1
[    0.357158] No ATAGs?
[    0.357199] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.450275] raid6: neonx2   gen()  1849 MB/s
[    0.518230] raid6: neonx2   xor()  1137 MB/s
[    0.518243] raid6: using algorithm neonx2 gen() 1849 MB/s
[    0.518253] raid6: .... xor() 1137 MB/s, rmw enabled
[    0.518262] raid6: using intx1 recovery algorithm
[    0.530732] edma 49000000.edma: TI EDMA DMA engine driver
[    0.537865] SCSI subsystem initialized
[    0.538410] libata version 3.00 loaded.
[    0.538830] usbcore: registered new interface driver usbfs
[    0.538934] usbcore: registered new interface driver hub
[    0.539060] usbcore: registered new device driver usb
[    0.539881] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[    0.539948] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[    0.541671] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    0.541988] media: Linux media interface: v0.10
[    0.542075] Linux video capture interface: v2.00
[    0.542207] pps_core: LinuxPPS API ver. 1 registered
[    0.542291] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.542337] PTP clock support registered
[    0.543483] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.545093] NetLabel: Initializing
[    0.545116] NetLabel:  domain hash size = 128
[    0.545124] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.545218] NetLabel:  unlabeled traffic allowed by default
[    0.545633] clocksource: Switched to clocksource ipipe_tsc
[    0.712405] NET: Registered protocol family 2
[    0.713359] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.713411] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.713453] TCP: Hash tables configured (established 4096 bind 4096)
[    0.713543] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.713566] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.713927] NET: Registered protocol family 1
[    0.714612] RPC: Registered named UNIX socket transport module.
[    0.714631] RPC: Registered udp transport module.
[    0.714640] RPC: Registered tcp transport module.
[    0.714649] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.715708] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.719183] audit: initializing netlink subsys (disabled)
[    0.719291] audit: type=2000 audit(0.716:1): initialized
[    0.720248] [Xenomai] scheduling class idle registered.
[    0.720265] [Xenomai] scheduling class rt registered.
[    0.720437] I-pipe: head domain Xenomai registered.
[    0.729809] [Xenomai] Cobalt v3.0.6 (Stellar Parallax) [DEBUG]
[    0.742475] zbud: loaded
[    0.743283] VFS: Disk quotas dquot_6.6.0
[    0.743599] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.747196] NFS: Registering the id_resolver key type
[    0.747284] Key type id_resolver registered
[    0.747295] Key type id_legacy registered
[    0.747330] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.747780] fuse init (API version 7.23)
[    0.748631] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    0.759928] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.760257] io scheduler noop registered
[    0.760280] io scheduler deadline registered
[    0.760367] io scheduler cfq registered (default)
[    0.762455] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.763530] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0
[    0.763744] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1
[    0.763760] gpio-of-helper ocp:cape-universal: ready
[    0.765485] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    0.767875] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.772066] console [ttyS0] disabled
[    0.772179] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[    0.785579] console [ttyS0] enabled
[    0.787606] [drm] Initialized drm 1.1.0 20060810
[    0.789524] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.790086] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.790426] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.790741] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.845688] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    0.845718] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    0.846320] davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[    0.847752] libphy: 4a101000.mdio: probed
[    0.847785] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    0.848690] cpsw 4a100000.ethernet: Detected MACID = 40:bd:32:e0:d9:3b
[    0.848866] cpsw 4a100000.ethernet: cpts: overflow check period 2125
[    0.851317] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.851395] ehci-platform: EHCI generic platform driver
[    0.851695] ehci-omap: OMAP-EHCI Host Controller driver
[    0.852330] usbcore: registered new interface driver usb-storage
[    0.855331] 47401300.usb-phy supply vcc not found, using dummy regulator
[    0.858534] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    0.858562] musb-hdrc: MHDRC RTL version 2.0
[    0.858574] musb-hdrc: setup fifo_mode 4
[    0.858603] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    0.860674] 47401b00.usb-phy supply vcc not found, using dummy regulator
[    0.863624] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    0.863652] musb-hdrc: MHDRC RTL version 2.0
[    0.863663] musb-hdrc: setup fifo_mode 4
[    0.863689] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    0.863858] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.863902] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    0.864265] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.864281] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.864294] usb usb1: Product: MUSB HDRC host driver
[    0.864305] usb usb1: Manufacturer: Linux 4.4.113-ti-xenomai-r149 musb-hcd
[    0.864317] usb usb1: SerialNumber: musb-hdrc.1.auto
[    0.865489] hub 1-0:1.0: USB hub found
[    0.865567] hub 1-0:1.0: 1 port detected
[    0.878033] mousedev: PS/2 mouse device common for all mice
[    0.881201] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    0.882605] i2c /dev entries driver
[    0.884901] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    0.886041] omap_hsmmc 48060000.mmc: Got CD GPIO
[    0.951844] hidraw: raw HID events driver (C) Jiri Kosina
[    0.952850] usbcore: registered new interface driver usbhid
[    0.952866] usbhid: USB HID core driver
[    0.953283] ashmem: initialized
[    0.955507]  remoteproc0: wkup_m3 is available
[    0.955529]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[    0.955541]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    0.967373] NET: Registered protocol family 10
[    0.969162] mip6: Mobile IPv6
[    0.969197] NET: Registered protocol family 17
[    0.969367] Key type dns_resolver registered
[    0.969389] mpls_gso: MPLS GSO support
[    0.969879] omap_voltage_late_init: Voltage driver support not added
[    0.977231] PM: Cannot get wkup_m3_ipc handle
[    0.981887] ThumbEE CPU extension supported.
[    0.983385] registered taskstats version 1
[    0.983668] zswap: loaded using pool lzo/zbud
[    0.988534] Btrfs loaded
[    0.990982] Key type encrypted registered
[    0.994631] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/input/input0
[    0.995862] mmc1: MAN_BKOPS_EN bit is not set
[    0.999617] mmc1: new high speed MMC card at address 0001
[    1.000583] mmcblk1: mmc1:0001 M62704 3.56 GiB
[    1.000974] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[    1.001321] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[    1.003145]  mmcblk1: p1 p2
[    1.021297] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.022132] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.022201] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.023880] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    1.025339]  remoteproc0: powering up wkup_m3
[    1.025374]  remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[    1.025900]  remoteproc0: remote processor wkup_m3 is now up
[    1.025924] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[    1.031346] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,00C0,2818BBBK0032'
[    1.031386] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[    1.069681] bone_capemgr bone_capemgr: slot #0: No cape found
[    1.109668] bone_capemgr bone_capemgr: slot #1: No cape found
[    1.149668] bone_capemgr bone_capemgr: slot #2: No cape found
[    1.189708] bone_capemgr bone_capemgr: slot #3: No cape found
[    1.189825] bone_capemgr bone_capemgr: initialized OK.
[    1.190289] PM: bootloader does not support rtc-only!
[    1.191452] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[    1.191488] of_cfs_init
[    1.191637] of_cfs_init: OK
[    1.199732] PM: Hibernation image not present or could not be loaded.
[    1.209978] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.210092] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.210997] devtmpfs: mounted
[    1.211601] Freeing unused kernel memory: 456K
[    1.401825] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[    1.473511] systemd[1]: System time before build time, advancing clock.
[    1.526958] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.531046] usb 1-1: New USB device found, idVendor=1f38, idProduct=001e
[    1.531074] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.531086] usb 1-1: Product: QUNEO
[    1.531097] usb 1-1: Manufacturer: KESUMO, LLC
[    1.559099] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[    1.562630] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[    1.576229] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    1.577059] systemd[1]: Detected architecture arm.
[    1.578425] systemd[1]: Set hostname to <bela>.
[    1.779792] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 26 bits of entropy available)
[    1.812283] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 27 bits of entropy available)
[    1.855642] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 28 bits of entropy available)
[    1.861981] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 28 bits of entropy available)
[    1.932745] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[    1.933056] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[    1.933475] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[    1.934637] random: systemd: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[    2.186782] systemd[1]: Reached target Swap.
[    2.189057] systemd[1]: Created slice User and Session Slice.
[    2.189576] systemd[1]: Listening on fsck to fsckd communication Socket.
[    2.190534] systemd[1]: Listening on udev Control Socket.
[    2.191027] systemd[1]: Listening on Syslog Socket.
[    2.191238] systemd[1]: Reached target Remote File Systems.
[    2.191608] systemd[1]: Listening on udev Kernel Socket.
[    2.192431] systemd[1]: Listening on Journal Audit Socket.
[    2.192882] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.193436] systemd[1]: Listening on Journal Socket.
[    2.194476] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.196381] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.198413] systemd[1]: Created slice System Slice.
[    2.199993] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    2.201071] systemd[1]: Reached target Slices.
[    2.207149] systemd[1]: Mounting POSIX Message Queue File System...
[    2.221182] systemd[1]: Starting Load Kernel Modules...
[    2.364544] systemd[1]: Mounting Debug File System...
[    2.379741] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    2.381644] systemd[1]: Created slice system-getty.slice.
[    2.399618] rtdm_pruss_irq: loading out-of-tree module taints kernel.
[    2.400526] rtdm_pruss_irq version 1 loaded
[    2.448949] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    2.547701] systemd[1]: Starting Journal Service...
[    2.548510] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    2.658953] systemd[1]: Starting File System Check on Root Device...
[    2.659734] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.660017] systemd[1]: Reached target Encrypted Volumes.
[    2.660223] systemd[1]: Reached target Paths.
[    2.785568] systemd[1]: Mounted POSIX Message Queue File System.
[    2.806248] systemd[1]: Mounted Debug File System.
[    2.826857] systemd[1]: Started Load Kernel Modules.
[    2.837446] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    2.910770] systemd[1]: Started File System Check Daemon to report status.
[    2.964304] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.048453] systemd[1]: Mounting FUSE Control File System...
[    3.204077] systemd[1]: Starting Apply Kernel Variables...
[    3.344248] systemd[1]: Mounting Configuration File System...
[    3.502889] systemd[1]: Mounted FUSE Control File System.
[    3.505526] systemd[1]: Started File System Check on Root Device.
[    3.559342] systemd[1]: Started Create Static Device Nodes in /dev.
[    3.571864] systemd[1]: Started Apply Kernel Variables.
[    3.573344] systemd[1]: Mounted Configuration File System.
[    3.644134] systemd[1]: Starting udev Kernel Device Manager...
[    3.694327] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.767288] systemd[1]: Started Journal Service.
[    3.893154] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    4.326882] systemd-journald[111]: Received request to flush runtime journal from PID 1
[    6.642312] usbcore: registered new interface driver snd-usb-audio
[    6.703374] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    7.426719] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    7.613528] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    9.863363] random: nonblocking pool is initialized
[    9.910054] using random self ethernet address
[    9.910091] using random host ethernet address
[   10.054099] using random self ethernet address
[   10.054134] using random host ethernet address
[   10.213843] Mass Storage Function, version: 2009/09/11
[   10.213880] LUN: removable file: (no medium)
[   12.103729] usb0: HOST MAC be:1a:32:e0:d9:3c
[   12.104235] usb0: MAC be:1a:32:e0:d9:3d
[   12.107632] usb1: HOST MAC be:1a:32:e0:d9:3f
[   12.107988] usb1: MAC be:1a:32:e0:d9:40
[   13.270062] net eth0: initializing cpsw version 1.12 (0)
[   13.270098] net eth0: initialized cpsw ale version 1.4
[   13.270111] net eth0: ALE Table size 1024
[   13.272710] net eth0: phy found : id is : 0x7c0f1
[   13.317192] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.797464] configfs-gadget gadget: high-speed config #1: c
[   20.708537] rtdm_pruss_irq_open
[   20.708915] Registering PRU interrupt:
                 PRU ICSS system event: 20
                 PRU INTC channel: 4
                 PRU INTC host interrupt: 4
                 ARM IRQ number:  22
[   20.708941] rtdm_pruss_irq linux_irq: 180 for arm_irq_handle_number: 22
[   20.708950] INITING_PRU: system_event: 20, intc_channel: 4, intc_host: 4
[   20.708958] : 0XD00 = 0XFFFFFFFF [u32]
[   20.708966] : 0XD04 = 0XFFFFFFFF [u32]
[   20.708973] : 0XD80 = 0X0 [u32]
[   20.708981] : 0XD84 = 0X0 [u32]
[   20.708989] cmr_reg
[   20.708997] : 0X414 = 0X4 [u8]
[   20.709005] hmr_reg
[   20.709011] : 0X804 = 0X4 [u8]
[   20.709018] secr0
[   20.709024] : 0X280 = 0XFFFFFFFF [u32]
[   20.709032] secr1
[   20.709038] : 0X284 = 0XFFFFFFF [u32]
[   20.709045] eisr_reg
[   20.709051] : 0X28 = 0X14 [u32]
[   20.709058] hieisr_reg
[   20.709064] : 0X34 = 0X4 [u32]
[   20.709072] hier
[   20.709078] hier read: 10
[   20.709084] esr0
[   20.709091] : 0X300 = 0X100000 [u32]
[   20.709098] intc_ger
[   20.709104] : 0X10 = 0X1 [u32]
[  332.542845] rtdm_pruss_irq_close
[  332.542887] rtdm_irq_free
[  332.542901] rtdm_event_pulse
[  332.542911] rtdm_event_destroy
[  336.813308] rtdm_pruss_irq_open
[  336.813738] Registering PRU interrupt:
                 PRU INTC channel: 4
                 ARM IRQ number:  22
[  336.813762] rtdm_pruss_irq linux_irq: 180 for arm_irq_handle_number: 22
[  336.813772] INITING_PRU: system_event: 20, intc_channel: 4, intc_host: 4
[  336.813780] : 0XD00 = 0XFFFFFFFF [u32]
[  336.813787] : 0XD04 = 0XFFFFFFFF [u32]
[  336.813795] : 0XD80 = 0X0 [u32]
[  336.813802] : 0XD84 = 0X0 [u32]
[  336.813810] cmr_reg
[  336.813820] : 0X414 = 0X4 [u8]
[  336.813827] hmr_reg
[  336.813833] : 0X804 = 0X4 [u8]
[  336.813840] secr0
[  336.813846] : 0X280 = 0XFFFFFFFF [u32]
[  336.813853] secr1
[  336.813860] : 0X284 = 0XFFFFFFF [u32]
[  336.813867] eisr_reg
[  336.813873] : 0X28 = 0X14 [u32]
[  336.813880] hieisr_reg
[  336.813886] : 0X34 = 0X4 [u32]
[  336.813893] hier
[  336.813899] hier read: 10
[  336.813906] esr0
[  336.813912] : 0X300 = 0X100000 [u32]
[  336.813920] intc_ger
[  336.813926] : 0X10 = 0X1 [u32]
[  346.526473] rtdm_pruss_irq_close
[  346.526515] rtdm_irq_free
[  346.526528] rtdm_event_pulse
[  346.526538] rtdm_event_destroy
[  722.967968] rtdm_pruss_irq_open
[  722.968336] Registering PRU interrupt:
                 PRU INTC channel: 4
                 ARM IRQ number:  22
[  722.968362] rtdm_pruss_irq linux_irq: 180 for arm_irq_handle_number: 22
[  722.968371] INITING_PRU: system_event: 20, intc_channel: 4, intc_host: 4
[  722.968379] : 0XD00 = 0XFFFFFFFF [u32]
[  722.968387] : 0XD04 = 0XFFFFFFFF [u32]
[  722.968395] : 0XD80 = 0X0 [u32]
[  722.968402] : 0XD84 = 0X0 [u32]
[  722.968410] cmr_reg
[  722.968419] : 0X414 = 0X4 [u8]
[  722.968426] hmr_reg
[  722.968432] : 0X804 = 0X4 [u8]
[  722.968439] secr0
[  722.968446] : 0X280 = 0XFFFFFFFF [u32]
[  722.968453] secr1
[  722.968459] : 0X284 = 0XFFFFFFF [u32]
[  722.968466] eisr_reg
[  722.968472] : 0X28 = 0X14 [u32]
[  722.968479] hieisr_reg
[  722.968485] : 0X34 = 0X4 [u32]
[  722.968493] hier
[  722.968499] hier read: 10
[  722.968505] esr0
[  722.968512] : 0X300 = 0X100000 [u32]
[  722.968519] intc_ger
[  722.968525] : 0X10 = 0X1 [u32]
[  759.719807] rtdm_pruss_irq_close
[  759.719841] rtdm_irq_free
[  759.719854] rtdm_event_pulse
[  759.719864] rtdm_event_destroy
a month later
@giuliomoro
i got this timeout errors yesterday three times when working on a project. is this something to be worried about? is my BELA slowly failing?
Sorry I forgot to reply to the previous message. This just normally means there has been an error in the digital communication between the PRU and the codec. I should make that message more meaningful and less worrying. It's still there as a leftover from the days where we didn't know what was happening. This case is already (more or less) gracefully handled for the CTAG (by restarting the audio when this happens), but not yet for the Bela capes.
Normally we see these errors happen when plugging/unplugging devices to the board. Is that what is happening to you? Or does it happen while the board is not even being touched?
    giuliomoro no problem...
    would disconnecting usb midi devices fall in that category? (although i was not aware of doing that yesterday)
    other then that, there is nothing connected.
    since the program crashes immediately, this would kind of defeat the purpose of your midi reconnect patch. but the PRU timeout does bot happen everytime i unplug the midi device.
      lokki would disconnecting usb midi devices fall in that category?
      no, normally USB is not a problem. It happens to me sometimes when I plug an audio cable in that generates a ground loop, at which point some noise is injected in the McASP and I get the timeout and need to restart the program. I will try to get the graceful handling to work.
      In the meantime, you may want to check that you have no loose wire connections in your setup. If you suspect it's an issue with the board itself, email me and you can send it back for replacement.
        giuliomoro In the meantime, you may want to check that you have no loose wire connections in your setup.
        there is nothing connected besides the usb device and an sm-58 and headphones.
        i have a not so sturdy xlr to jack cable at the audio input, probably that is the cause then...
        Are you clipping the input heavily perhaps? It's not like I have seen that cause this issue, but worth checking
