We normally use usb batteries such as those used to charge mobile phones. Clearly on BelaMini these could be much larger than the board itself. So if space is at a premium, you may need to use lipo batteries. A boost converter to increase the DC voltage from 3.7V to 5V would be needed in that case if you want to use the analog inputs (audio would work fine without). There is an ongoing discussion here
