heliopolarthing Do you think that these multiple "warnings" hinder the proper functioning of the operation? Or is this normal?
there's nothing of concern there.
heliopolarthing The test with the patch including the ggee/moog~ object seems ok insofar as the object appears well on the IDE and is well connected!
the fact that the object shows up in the IDE and has connections unfortunately does not mean it is recognised. Check the IDE's console for any "couldn't create" errors. If there are none, then you can assume it's all good.
Btw, also ggee seems to be available for Linux-armv7-32 from deken.
