and here they are in my spiced up rack 🙂
I've got a few thing already running on Salt, so my plan is to make those also build and work on Pepper,
mainly I just need to change the 'UI', from the four led buttons, to use 2 buttons and led strip.
(most of the voltage differences are already accounted for since I was 'testing' on the bela board)
my next steps :
- have pepper doing patch swapping as salt does.
- look into a build a calibration program for I/O so that I can have calibrate I/O for both salt and pepper
patch swapping, I guess will be a 'long press' on button 1
calibration
idea is run a calibration program, that builds a calibration file for IO off known voltages.
then a small cal 'library' that i'll use in each patch, that read that file, and then adjust input and output accordingly.
(*) I won't get full voltage range, but idea is over the range i can get it will be pretty accurate for v/oct tracking etc
