Giuliomore,
1) My bela looks like this:
https://cdn.hackaday.io/images/resize/600x600/8340691488747287236.jpg
2) bela.local doesn't work
3) ssh just hangs,and times out
4) ifconfig included below.
5) in terms of IP, As requested by the docs I've set the configuration IPv4 option to "Using DHCP w manual address" and the IP to 192.168.7.1 (note I've tried ....6.1 and ....7.1)
6) At some point it did say "beagleboneblack" in network configs but that reads "not connected" now.
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
XHC1: flags=0<> mtu 0
XHC0: flags=0<> mtu 0
XHC20: flags=0<> mtu 0
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether ac:de:48:00:11:22
inet6 fe80::aede:48ff:fe00:1122%en5 prefixlen 64 scopeid 0x7
media: autoselect
status: active
ether 8c:85:90:ca:c9:cc
inet6 fe80::1415:ab08:f28a:46f9%en0 prefixlen 64 secured scopeid 0x8
inet 10.0.1.2 netmask 0xffffff00 broadcast 10.0.1.255
media: autoselect
status: active
ether 0e:85:90:ca:c9:cc
media: autoselect
status: inactive
ether 9a:49:37:40:52:16
inet6 fe80::9849:37ff:fe40:5216%awdl0 prefixlen 64 scopeid 0xa
media: autoselect
status: active
en8: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=60<TSO4,TSO6>
ether 42:00:b5:58:eb:01
status: inactive
en9: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 42:00:b5:58:eb:00
status: inactive
en10: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 42:00:b5:58:eb:05
status: inactive
en11: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 42:00:b5:58:eb:04
status: inactive
bridge0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
Configuration:
ipfilter disabled flags 0x2
member: en8 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 11 priority 0 path cost 0
member: en9 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 12 priority 0 path cost 0
member: en10 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 13 priority 0 path cost 0
member: en11 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 14 priority 0 path cost 0
media: <unknown type>
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::d1c8:6cd3:12e2:33ac%utun0 prefixlen 64 scopeid 0x11
en14: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 9a:1f:85:1c:3d:0e
inet6 fe80::e9:7a54:384d:11fd%en14 prefixlen 64 secured scopeid 0x12
inet 192.168.7.1 netmask 0xffffffff broadcast 192.168.7.1
media: autoselect
status: active
