I see a fritzing file for the Bela, but not that Bela Mini. Does anybody have a version?
5 days later
12 days later
That is great! Looks nice, great for documenting prototypes and blogging. Thanks!
Oh, but one problem. It seems I can only connect certain pins (those that show up red). However, in my projects I use many of the other pins. Is it easy to add every pin, even if they are generically label P1_3?
Thanks.
@astrid, adding you here since you created the original. Possible to add all the pins?
3 months later
Hello Paul,
This reply is horrendously late - I started taking on the (horrible) Fritzing part editing process and then the Trill Kickstarter campaign happened! Thanks for flagging this - I wasn't sure if I should add all the pins so this feedback is really useful, and I've now made entirely new parts for both Bela and Bela Mini.
I've updated the Wiki with links to both: https://github.com/BelaPlatform/Bela/wiki/Fritzing-file
Please do try it out and let me know if you run into any more problems. Thanks! 🙂
