If I use some of the analogue outs on Bela as audio outs with the settings at 22.05 but the audio coming from PureData at 44.1, how is the downsampling dealt with? Does Bela just throw away every other sample or is there some interpolation? Is any filtering done automatically in software?
Similarly, if PureData is trying to record audio using tabwrite~ at 44.1kHz and the analogue in is only running at 22.05, what will happen?
In both cases, I would rather have a lo-fi signal with audible aliasing than the muddy sound of audio that has been lowpass filtered at 11kHz! I hope I don't have to run PD at a lower sample rate in order to use the analogue ins and outs at a lower sample rate because PD sounds so mushy (filtered!) if you run it at low sample rates.
