Hi,
I followed this guide to run Faust code on Bela. Unfortunately when I run faust2bela -tobela simpleFX_Analog.dsp I get a bunch of compiler errors.
Bela image: v0.3.6b
Faust version from the guide, so 09ad59955eccb522382d60d58fb648e9b0fb4a78
Am I doing something wrong? Thanks in advance.
Compiler output:
Building render.cpp...
/root/Bela/projects/simple/render.cpp:8545:17: error: use of undeclared identifier 'itemInfo'
std::vector<itemInfo*> fUiItems;
/root/Bela/projects/simple/render.cpp:8545:26: error: expected expression
/root/Bela/projects/simple/render.cpp:8642:21: error: use of undeclared identifier 'itemInfo'
std::vector<itemInfo*>::iterator it;
/root/Bela/projects/simple/render.cpp:8642:30: error: expected expression
/root/Bela/projects/simple/render.cpp:8642:31: error: no type named 'iterator' in the global namespace; did you mean 'MidiMeta::iterator'?
MidiMeta::iterator
/usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0/../../../../include/c++/6.3.0/bits/stl_map.h:149:58: note: 'MidiMeta::iterator' declared here
typedef typename _Rep_type::iterator iterator;
/root/Bela/projects/simple/render.cpp:8644:37: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
std::string type = (*it)->type;
/root/Bela/projects/simple/render.cpp:8644:39: error: no member named 'type' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
/root/Bela/projects/simple/render.cpp:8663:37: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
/root/Bela/projects/simple/render.cpp:8663:39: error: no member named 'type' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
/root/Bela/projects/simple/render.cpp:8666:26: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
if ((*it)->address != "") {
/root/Bela/projects/simple/render.cpp:8666:28: error: no member named 'address' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
/root/Bela/projects/simple/render.cpp:8667:42: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
fPathInputTable[(*it)->address] = std::make_pair(std::atoi((*it)->index.c_str()), &fInControl[counterIn]);
/root/Bela/projects/simple/render.cpp:8667:44: error: no member named 'address' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
/root/Bela/projects/simple/render.cpp:8667:85: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
/root/Bela/projects/simple/render.cpp:8667:87: error: no member named 'index' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
/root/Bela/projects/simple/render.cpp:8669:55: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
fInControl[counterIn] = STR2REAL((*it)->init);
/root/Bela/projects/simple/render.cpp:8669:57: error: no member named 'init' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
/root/Bela/projects/simple/render.cpp:8674:26: error: member reference type 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >' is not a pointer; did you mean to use '.'?
/root/Bela/projects/simple/render.cpp:8674:28: error: no member named 'address' in 'std::pair<const std::__cxx11::basic_string<char>, std::__cxx11::basic_string<char> >'
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
Makefile:434: recipe for target '/root/Bela/projects/simple/build/render.o' failed
make: *** [/root/Bela/projects/simple/build/render.o] Error 1
