When trying to update I get an error (previously it worked):
Offline update failed during 'before upgrade': Script exited with code 1.
Log output:
- GREP='grep ://deb.bela.io/'
- APT_OFFLINE=apt-offline
- HARDCODED_UPDATE_BEFORE=1
- PKGS='bela-all bela-ide'
- WHAT=offline
- ACTION=upgrade
- '[' offline '!=' offline ']'
- TMPDIR=/tmp/bela-offline-update-workflow/
- mkdir -p /tmp/bela-offline-update-workflow/
- '[' upgrade == check ']'
- '[' 5 -ne 5 ']'
- WHEN=before
- LIST_FILE=/tmp/bela-apt-offline-work/bela-apt-offline-list.txt
- DOWNLOADS_DIR=/tmp/bela-apt-offline-work
- sudo mkdir -p /var/cache/apt/archives/partial
- sudo mkdir -p /var/lib/apt/lists/partial
- mkdir -p /tmp/bela-apt-offline-work
++ mktemp /tmp/bela-offline-update-workflow//offline-upgrade.sig.XXXX
- SIG=/tmp/bela-offline-update-workflow//offline-upgrade.sig.GcUB
- '[' upgrade '!=' update -a upgrade '!=' upgrade ']'
- '[' before '!=' before -a before '!=' after -a before '!=' download ']'
- '[' before == before ']'
- '[' upgrade == upgrade ']'
- sudo apt-offline set /tmp/bela-offline-update-workflow//offline-upgrade.sig.GcUB --upgrade --install-packages bela-all bela-ide
Gathering details needed for 'upgrade' operation
- grep 'is of 0 bytes' /tmp/bela-offline-update-workflow//offline-upgrade.sig.GcUB-stderr
- cat /tmp/bela-offline-update-workflow//offline-upgrade.sig.GcUB-stderr
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
- exit 1
