Hey !
thanks again @giuliomoro 🙂
Sorry for the long mess incoming
We have two set up _
two BelaGemMulti running PD patches
Set up 1_ patchuse 3 read sf
-[readsf 10] trigg by a bonk (link to an audiojacks from the minimad sending a clic at begining of the loop to get sync)
bang at ending, reload and wait to replay
-[readsf 2] is used to create an invisble loop, it's banged after a delay wich start from the received bonk bang
-[readsf 2] is another player asychrone bang at end, reload and replay etc.
Set up 2 _ this one is autonome,
-[readsf 4] bang at end, reload and replay etc.
-[readsf 2] is used to create an invisble loop, it's banged after a delay wich start from the received bang received at the end of the player
The set up 2 is the first wich went wrong, slowly sound like guns, crackling glitchy sound appeared.
The only way I found to solve was to erase and reload the project on the board.
When i removed the "sick" Bela crackling etc, I've launch it away from the set up from my pc, bug was still present but nothing was printed in the console.
Slowly this prob appear in set up 2, I did the same things.
All the audio set up, patch, sync worked perfectly the first 3 days, this i why I'm questionning something external like power supply, external power tension or others.
I defo need to find a way to monitor the boards, thanks for the link, i didn't knew that some board like this exist, top 🙂
I will dive in the IDE saving logs options to set it up ! thx.
What I did at now :
We change the Bela and Beagle with the spare we buyed in set up 2 ( I've monitor the patch for like 2/3h x2 days from the board before set it up) : No problems at home - after 45min Bela audio stopped to work ( i had to reboot her to relaunch audio)
I've also reload the project on the Bela of SetUp 1 and sometimes audio is cuting while keeping playing just cut in play.
sorry again for the long mess, very very in the fog with all of this, thanks again so much for your times and ideas 🙂
ebl
