Hi, Ive been trying all day to get the Gliss to show a yellow button flash on an incoming clock from an Intelijel Midi 1u with no joy.
The Gliss is in record mode () , with mode LEDs showing as per the video manual (green, red, yellow)
the clock output is definitely clocking, because it can successfully clock a range of other modules (clouds, morphagene etc) all of them showing clock indicators and keeping time.
but if I run a clock into the Bela Gliss there's no led indication and no response. If I arm the record (physical button, red LED) the recording doesnt work and the record arm cannot be unarmed (LED button stays red until i tap three times )
I can get the gliss to respond to a -5 / +5 LFO , it arms records and playsback in clock mode. clocking off the pulsewave LFO.
I tested the voltage ranges and I cant get the gliss to respond to triggers (or gates of any length) from 0 to 5v, and similarly ( as I said) its unresponsive to clock 0-5v
I tried setting the Gliss input voltage range to expect 0-5v ,
this does not help the situation though. Still no response to triggers, gates or clocks.
I tried trigger mode (orange mode) and the Gliss does not respond to triggers either
unplugging the gate/clock/trigger and setting to clock mode - the device will record as expected (free running)
Any suggestions?
