that's great. Next step to integrate into a Bela program: the code in the loop() function is not suitable to run inside render(), as it would disrupt the regular audio processing. What you should do, instead, is running it in a separate thread, using an AuxiliaryTask. For instance:
// paste here the code from MasterTest.cpp before setup()
void sensorLoop(void* arg)
while(!gShouldStop)
//// paste here the code from the loop() function in MasterTest.cpp
//// test it as it is, at first, then edit it is as needed to set global
//// variables that you can access from within render()
/// make sure you include the closing line `usleep(100000);`
// paste here the code from `setup()` in `MasterTest.cpp`
Bela_scheduleAuxiliaryTask(Bela_createAuxiliaryTask(sensorLoop, 50, "sensorLoop", NULL));
// perform your audio processing.
// access the global variable set in sensorLoop()
void cleanup(BelaContext* context, void* userData)
