Hi,
I'm trying to use electret microphones with the Bela Gem Multi through the AUDIO ports. I would like to bias with a 3.3V signal, Ideally, I'd use a clean low noise reference. I found that audio channels 3-10 use TLV320ADC3140 codec, and from its spec sheet there is listed a MICBIAS. Could anyone tell me whether the MICBIAS is accessible? Is it broken out to the extension wing for example?
Edit: Or, have I missed something and is biasing done automatically through the 3.5mm jack?
Thanks in advance, Rick.
