jestern77 Hi I'm trying to port an old Pure Data project into the Bela Gem Multi and MIDI is not working, I tried also adding [loadbang] | [hw 1 0 0 < | [send bela_setMidi] but nothing works. Is there something I could try?
giuliomoro Does it show up when running lsusb in the console? What version of the board have you got?
jestern77 yes! lsusb Bus 001 Device 003: ID 0944:010f KORG, Inc. nanoKONTROL studio controller Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Should I change the message in the startup?
giuliomoro jestern77 but nothing works. Is what gets printed when the program starts? Also try running amidi -l (assuming you have the latest image).
jestern77 I have trouble updating the system: Update Bela automatically System Update Error Report: Offline update failed during 'before update': spawn bela-update ENOENT Maybe I can do it manually? Is there a .db file somehwere?
giuliomoro Yeah, no. reflash the SD card. Instructions here https://learn.bela.io/get-started-guide/bela-gem-get-started
