Great, thank you!
I verified that the Sliders example is working now.
FWIW there are some 404 errors in the console - I'm pasting them here in case that's of use. Thanks again.
`Socket opened on ws://bela.local:5555/gui_data
BelaWebSocket.js:67 Socket opened on ws://bela.local:5555/gui_control
BelaControl.js:122 __NEW_CONNECTION__
BelaControl.js:124 Project name: bela-example-tmp-085c4c88-f49b-45aa-9662-3a6f7a880633
BelaControl.js:139 _SET CONTROLLER_
api/read/file/bela-example-tmp-085c4c88-f49b-45aa-9662-3a6f7a880633%2Fsketch.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
GuiHandler.js:206 _LOADED_
projects/bela-example-tmp-085c4c88-f49b-45aa-9662-3a6f7a880633/main.html:1 Failed to load resource: the server responded with a status of 404 (Not Found)
utils.js:39 request rejected
GuiHandler.js:188 HTML not loaded...
GuiHandler.js:189 ... try loading script
poppins-regular-webfont.woff2:1 Failed to load resource: the server responded with a status of 404 (Not Found)
poppins-regular-webfont.woff:1 Failed to load resource: the server responded with a status of 404 (Not Found)`
