Hello, I am trying to understand the DC-coupled capabilities of the Bela Gem multi, I am trying to build a matrix mixer for Behringer Neutron, I got some Y minijack TRS to female mono 3.5mm cables and I am doing a simple test of a RNBO~ patch that connects audio in 2-9 to audio out 2-9 and then I just connect the Neutron's LFO to Osc1 pitch through Bela, it kinda works but the range is not the same as when connecting it abridged.
I found the following info on the crowdsupply page:
"DC-coupled Audio Inputs: we have added support for DC-coupled connections to audio inputs 2-9 on the Bela Gem Multi. When coupled with suitable level-shifting circuitry, this will let you use these eight audio inputs for CVs or other low-frequency signals. DC-coupled inputs will be available when connecting directly to the pin headers on the Multi cape; the 3.5 mm TRS audio jacks will be AC-coupled as before, as this configuration provides the best noise performance for most audio applications.
Using DC coupling with the audio inputs requires some changes in software settings, which will be selectable via the Bela IDE. It also requires an external preamplifier circuit to shift the input levels to the right range (strictly between 0 and 3.3 V, and centered around a 1.375 V reference which is required by the ADC). We will publish schematics for a level shifter after the campaign."
So how would I go about achieving what I am trying to do ? The wings are actually NOT dc-coupled? They kinda feel like they're DC-coupled their range is not the same as the straight connection, but it is not similar to non-dc coupled outputs that I've tried in the past. Also, has the level shifter schematics been published yet? Can't find anything. Also can't see any software settings regarding DC-coupling in bela IDE.
Any help to steer me in the right direction is greatly appreciated, what I'd like to have is simple; DC-coupled in/outs and the Bela working as a transparent mixer between the Neutron connections.
