My team and I are having a strange issue only when the Bela is connected to our ground. The guitar pedal we are making is a custom design so as not to confuse with proprietary designs and we have control over it. It has an AD823 opamp for signal mixing between an analog passthrough and the Bela output. There is a persistent 2.7KHz ring on the input and output when connected, regardless if the Bela is outputting a signal, but if the Bela is receiving power from a separate source/ground and the analog electronics are powered from their own source/ground, with only the ADC and DAC connected between both, the ring is nonexistent. Since we are making a self contained guitar pedal, this is where the issue lies.
From testing we are very sure the Bela is almost "poisoning" the ground and the ground noise that is injected is audible on the output jacks from the sinusoid generated. It follows the CPU thinking pattern underneath the ring as well. This ground is isolated to one single power adapter throughout, but ground loops may still be the issue.
We are filtering for LPF 19KHz on both the ADC and DAC, and have tried filtering 5V -> GND, but nothing has changed the ring at all. The output is sent to a regular fender guitar amp.
If anyone has had a similar issue before I could not find it and any help would be appreciated as this is the last step to completing the project.
