Hi everyone,
I’m currently working on a custom Modal Synthesizer project running on a Bela Gem Stereo using puredata. I’ve run into a bit of a wall trying to get digital inputs working within a Pure Data patch.
to give you context, this is the circuit im using for the hardware :
Circuit: A simple digital button in a breadboard which is wired correctly to the bela using a jumper cable and a resistor, and the button receives the GND of the bela too.
I have it connected to the pin labeled Digital 0 ( which the hardware identifies as D0, P1.21).
The Problem:
I am testing this in a clean Pd patch, but I can't seem to get a signal. I’ve tried the following logic based on the standard Bela examples:
Sent a [loadbang] to a [in 11( message connected to [ s bela_setDigital].
Attempted to read the signal using [r bela_digitalIn11] connected to a [print] object expecting the values get sent to the IDE console.
I noticed a discrepancy in the documentation/examples:
Most example projects refer to the digital input as the pin number 11, but the hardware seem to identify it as pin 21.
I tried changing the Pd message to [in 21( and reading from [r bela_digitalIn21] to match the physical header number, but still no luck. The hardware is powered, the wiring appears correct, and the rest of the Stereo Gem is functioning perfectly.
My Questions:
On the Bela Gem Stereo, what is the correct way to initialize Digital 0 as digital input?
Are there any additional steps required to initialize the digital pins on the Stereo Gem compared to the original Bela?
i just want to know how the bela gem stereo identifies the hardware digital pins and how a puredata project is able to read them.
sorry for my english, any guidance is appreciated! : )
