Can you help me integrate L3GD20H Gyro in a custom render.cpp to use it with PD?
I downloaded the library: https://github.com/adafruit/Adafruit_L3GD20
I uploaded Adafruit_L3GD20.h to Bela
I tried to integrate Adafruit_L3GD20.cpp in a custom render.cpp (copied the code into) but i got some errors.
I'll attach the custom render.cpp that that I use with Ultrasonic that is the one where i want to integrate the Gyro too.
Thanks a lot
/***** render.cpp *****/
/* mod by tomme to use ULTRASONIC SENSOR in Pure Data
____ _____ _ _
| __ )| ____| | / \
| _ \| _| | | / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/ \_\
http://bela.io
A project of the Augmented Instruments Laboratory within the
Centre for Digital Music at Queen Mary University of London.
http://www.eecs.qmul.ac.uk/~andrewm
(c) 2016 Augmented Instruments Laboratory: Andrew McPherson,
Astrid Bin, Liam Donovan, Christian Heinrichs, Robert Jack,
Giulio Moro, Laurel Pardue, Victor Zappi. All rights reserved.
The Bela software is distributed under the GNU Lesser General Public License
(LGPL 3.0), available here: https://www.gnu.org/licenses/lgpl-3.0.txt
#include <cmath>
#include <stdio.h>
#define PD_THREADED_IO
#include <libpd/z_libpd.h>
extern "C" {
#include <libpd/s_stuff.h>
#include <UdpServer.h>
#include <Midi.h>
#include <Scope.h>
#include <string>
#include <sstream>
#include <algorithm>
//ultrasonic
#include <stdlib.h>
#include <PulseIn.h>
PulseIn pulseIn;
int gTriggerInterval = 2646; // how often to send out a trigger. 2646 samples are 60ms
int gMinPulseLength = 7; //to avoid spurious readings
unsigned int gTriggerDigitalOutPin = 0; //channel to be connected to the module's TRIGGER pin - check the pin diagram in the IDE
unsigned int gEchoDigitalInPin = 1; //channel to be connected to the modules's ECHO pin (digital pin 1) - check the pin diagram in the IDE
int gTriggerCount = 0;
int gPrintfCount = 0;
//ultrasonic end
static unsigned int gScopeChannelsInUse = 4;
static unsigned int gFirstAnalogInChannel;
static unsigned int gFirstAnalogOutChannel;
settings->interleave = 0;
float* gInBuf;
float* gOutBuf;
#define PARSE_MIDI
void dumpMidi()
if(midi.size() == 0)
return;
"Num",
"Name",
"In",
"Out",
"Pd channels"
n,
gMidiPortNames[n].c_str(),
n * 16 + 1,
n * 16 + 16
Midi* newMidi;
newMidi = new Midi();
#ifdef PARSE_MIDI
newMidi->enableParser(true);
#else
newMidi->enableParser(false);
#endif /* PARSE_MIDI */
if(verboseSuccess)
if(newMidi->isInputEnabled())
if(verboseSuccess)
if(verboseError)
fprintf(stderr, "Failed to open MIDI device %s\n", name.c_str());
return nullptr;
} else {
return newMidi;
unsigned int port = 0;
while(*channel > 16){
*channel -= 16;
port += 1;
if(port >= midi.size()){
// if the port number exceeds the number of ports available, send out
// of the first port
port = 0;
return port;
midi[port]->writeNoteOn(channel, pitch, velocity);
midi[port]->writeControlChange(channel, controller, value);
midi[port]->writeProgramChange(channel, program);
midi[port]->writePitchBend(channel, value);
midi[port]->writeChannelPressure(channel, pressure);
midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
if(port > (int)midi.size()){
port = 0;
midi[port]->writeOutput(byte);
rt_printf("%s", received);
libpd_float((const char*)receiverName, (float)state);
// rt_printf("%s: %d\n", (char*)receiverName, state);
if(strcmp(source, "bela_setMidi") == 0){
int num[3] = {0, 0, 0};
if(!libpd_is_float(&argv[n]))
fprintf(stderr, "Wrong format for Bela_setMidi, expected:[hw 1 0 0(");
return;
if(newMidi)
midi.push_back(newMidi);
dumpMidi();
return;
bool disable = false;
direction = INPUT;
direction = OUTPUT;
disable = true;
} else {
return;
if(argc == 0){
return;
return;
int channel = libpd_get_float(&argv[0]) - gLibpdDigitalChannelOffset;
if(disable == true){
dcm.unmanage(channel);
return;
if(argc >= 2){
t_atom* a = &argv[1];
if(libpd_is_symbol(a)){
char *s = libpd_get_symbol(a);
if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
isMessageRate = false;
return;
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between gLibpdDigitalChannelOffset and (gLibpdDigitalCHannelOffset+gDigitalChannelsInUse)
unsigned int channel = receiver - gLibpdDigitalChannelOffset; // go back to the actual Bela digital channel number
if(channel < gDigitalChannelsInUse){ //number of digital channels
dcm.setValue(channel, value);
std::vector<std::string> gReceiverInputNames;
std::vector<std::string> gReceiverOutputNames;
void generateDigitalNames(unsigned int numDigitals, unsigned int libpdOffset, std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
std::string outBaseString = "bela_digitalOut";
receiverInputNames.push_back(inBaseString + std::to_string(i+libpdOffset));
receiverOutputNames.push_back(outBaseString + std::to_string(i+libpdOffset));
void printDigitalNames(std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
printf("DIGITAL INPUTS\n");
for(unsigned int i=0; i<gDigitalChannelsInUse; i++)
printf("%s\n", receiverInputNames[i].c_str());
printf("DIGITAL OUTPUTS\n");
printf("%s\n", receiverOutputNames[i].c_str());
#ifdef PD_THREADED_IO
void fdLoop(void* arg){
while(!gShouldStop){
sys_doio();
usleep(3000);
#endif /* PD_THREADED_IO */
Scope scope;
float* gScopeOut;
void* gPatch;
bool gDigitalEnabled = 0;
//ultrasonic
// Set the mode of digital pins
pinMode(context, 0, gEchoDigitalInPin, INPUT); // receiving from ECHO PIN
pinMode(context, 0, gTriggerDigitalOutPin, OUTPUT); // send to TRIGGER PIN
pulseIn.init(context, gEchoDigitalInPin, HIGH); //detect HIGH pulses on this pin
//ultrasonic end
// Check Pd's version
int major, minor, bugfix;
return false;
return false;
gDigitalEnabled = 1;
char file[] = "_main.pd";
char folder[] = "./";
return false;
free(str);
// analog setup
printf("Audio channels in use: %d\n", context->audioOutChannels);
printf("Analog channels in use: %d\n", gAnalogChannelsInUse);
printf("Digital channels in use: %d\n", gDigitalChannelsInUse);
// Channel distribution
gFirstAnalogInChannel = std::max(context->audioInChannels, context->audioOutChannels);
gFirstAnalogOutChannel = gFirstAnalogInChannel;
gFirstDigitalChannel = gFirstAnalogInChannel + std::max(context->analogInChannels, context->analogOutChannels);
gLibpdDigitalChannelOffset = gFirstDigitalChannel + 1;
// Create receiverNames for digital channels
generateDigitalNames(gDigitalChannelsInUse, gLibpdDigitalChannelOffset, gReceiverInputNames, gReceiverOutputNames);
// digital setup
if(gDigitalEnabled)
if(gDigitalChannelsInUse > 0){
dcm.setCallbackArgument(ch, (void*) gReceiverInputNames[ch].c_str());
unsigned int n = 0;
if(newMidi)
++n;
} else {
dumpMidi();
return false;
libpd_init();
gInBuf = get_sys_soundin();
gOutBuf = get_sys_soundout();
// start DSP:
// [; pd dsp 1(
libpd_start_message(1);
libpd_add_float(1.0f);
// Bind your receivers here
for(unsigned int i = 0; i < gDigitalChannelsInUse; i++)
libpd_bind(gReceiverOutputNames[i].c_str());
libpd_bind("bela_setMidi");
// open patch:
if(gPatch == NULL){
return false;
pdMultiplexerActive = true;
sys_dontmanageio(1);
AuxiliaryTask fdTask;
fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", NULL);
dcm.setVerbose(false);
//ultrasonic
for(unsigned int n = 0; n<context->digitalFrames; n++){
gTriggerCount++;
if(gTriggerCount == gTriggerInterval){
gTriggerCount = 0;
digitalWriteOnce(context, n / 2, gTriggerDigitalOutPin, HIGH); //write the status to the trig pin
} else {
digitalWriteOnce(context, n / 2, gTriggerDigitalOutPin, LOW); //write the status to the trig pin
int pulseLength = pulseIn.hasPulsed(context, n); // will return the pulse duration(in samples) if a pulse just ended
float duration = 1e6 * pulseLength / context->digitalSampleRate; // pulse duration in microseconds
static float distance = 0;
if(pulseLength >= gMinPulseLength){
static int count = 0;
duration = constrain(duration, 200, 900);
distance = ((duration - 200) / 700);
libpd_float("ultra1", distance);
++count;
//ultrasonic end
int num;
#ifdef PARSE_MIDI
switch(message.getType()){
case kmmNoteOn:
break;
case kmmNoteOff:
* with a velocity of 0.
break;
case kmmControlChange:
break;
case kmmProgramChange:
break;
break;
case kmmChannelPressure:
break;
case kmmPitchBend:
int value = ((message.getDataByte(1) << 7)| message.getDataByte(0)) - 8192;
break;
case kmmSystem:
int byte = channel | status;
break;
case kmmNone:
case kmmAny:
break;
#else
int input;
libpd_midibyte(port, input);
//audio input
memcpy(
gInBuf + n * gLibpdBlockSize,
// analog input
memcpy(
// multiplexed analog input
if(pdMultiplexerActive)
unsigned int j;
unsigned int k;
float* p0;
float* p1;
// digital input
if(gDigitalEnabled)
// digital in at message-rate
// digital in at signal-rate
// digital outputs
if(gDigitalEnabled)
// digital out at signal-rate
// scope output
gScopeOut[k] = *p1;
// audio output
memcpy(
//analog output
memcpy(
for(auto a : midi)
delete a;
libpd_closefile(gPatch);
delete [] gScopeOut;
