Hello, we are wondering whether it's possible or not to select an unique port of our trill craft sensor because we only need data from one port and others shouldn't give to our Arduino any information/data.
Also, our project needs to be faster so if the sensor is collecting data from one port after another (that means for example in one minute it might be checking 1 port 2 times to check all of the 30 ports if the speed is 1 check per second), but we're not sure that the sensor is working like that, maybe the data collect is done at the same time for every port.
So, is it possible to "select" one port and get rid of the others ? And if yes, can you give me the Arduino instruction to do that ? It would help us.
Thank you,
Miniplane
