Apologies if this is covered somewhere else! I have a Bela Mini board, and I understand that the headphone output is amplified by the TLV320AIC3104 codec for driving headphones. But I'm a bit confused that if I connect headphones to the line outputs, they seem to work just fine - no noticeable difference in volume or audio quality..? I've tried a few different sets of headphones with different impedances and this always seems to be the case.
Obviously I will continue to use the headphone outputs for headphones as intended - I'm just trying to understand why this is - e.g. if I connect my headphones to the line level output of my digital piano, there is no sound - so is the line output of the Bela Mini/TLV320AIC3104 codec unusually "hot"? Or is there something else in terms of impedance etc that I'm failing to understand..? Thanks!
