Hello Giulio,
After buying a new PocketBeagle 2 and plugging it into the Bela cape, the system has finally started to work — this seems solved on my end!
Meanwhile my school has purchased two Bela Gem Multi (cape + PocketBeagle 2) units with the SD already flashed. Both show the same symptom: red LED from the PB2 and blue LED from the Bela cape, both solid/steady, never entering the usual blinking heartbeat.
Checking from macOS (ioreg -p IOUSB -w0 -l), the PB2 enumerates on USB as "AM62x DFU" (Texas Instruments) rather than as a network device — no 192.168.7.2 interface ever appears. As far as I understand, this means the SoC's ROM bootloader isn't finding valid boot media and is falling back to USB DFU recovery mode, before Linux even starts.
I also tried reflashing via the BeagleBoard Imaging Utility, but it's not able to write to either unit.
Is this a known issue, and is there a recommended recovery procedure for this DFU state?
Thanks,
Guglielmo
