Thanks for clarifying.
The Bela is recognized in SystemSettings->Network with the ip address 192.168.7.1.
The terminal command returns an enormous amount of text. I've pasted the first part here, is that enough to go by or do you need the rest as well?
(base) ➜ ~ ifconfig;
ls /dev/ttybela;
ioreg -p IOUSB -w0 -l;
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
anpi2: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether b2:c8:94:2f:e0:46
media: none
status: inactive
anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether b2:c8:94:2f:e0:44
media: none
status: inactive
anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether b2:c8:94:2f:e0:45
media: none
status: inactive
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether b2:c8:94:2f:e0:24
media: none
status: inactive
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether b2:c8:94:2f:e0:25
media: none
status: inactive
en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether b2:c8:94:2f:e0:26
media: none
status: inactive
ether 36:ca:43:bd:b8:80
status: inactive
ether 36:ca:43:bd:b8:84
status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 36:ca:43:bd:b8:88
status: inactive
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 10 priority 0 path cost 0
ifmaxaddr 0 port 11 priority 0 path cost 0
member: en3 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 12 priority 0 path cost 0
media: <unknown type>
status: inactive
ap1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether 66:f9:e3:d4:90:77
media: autoselect (none)
status: inactive
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 constrained
ether ba:98:d2:7e:a3:dd
inet6 fe80::1cc8:556:3e81:c6f5%en0 prefixlen 64 secured scopeid 0xe
inet 172.20.10.13 netmask 0xfffffff0 broadcast 172.20.10.15
inet6 2a02:3032:65:61b4:c9f:7989:33a1:fa24 prefixlen 64 autoconf secured
inet6 2a02:3032:65:61b4:58ea:6f26:6626:859e prefixlen 64 autoconf temporary
media: autoselect
status: active
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
inet6 fe80::b752:5b20:34fd:eab0%utun0 prefixlen 64 scopeid 0x10
awdl0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 0e:09:b2:f5:67:d7
inet6 fe80::c09:b2ff:fef5:67d7%awdl0 prefixlen 64 scopeid 0x11
media: autoselect
status: active
inet6 fe80::c09:b2ff:fef5:67d7%llw0 prefixlen 64 scopeid 0x12
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::6bc4:c558:faea:c23%utun1 prefixlen 64 scopeid 0x13
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::de1d:4807:3c43:5a03%utun2 prefixlen 64 scopeid 0x14
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x15
en15: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 04:47:07:2d:c6:2f
inet6 fe80::881:4f0:b8f9:9a48%en15 prefixlen 64 secured scopeid 0x16
inet 192.168.7.1 netmask 0xffffff00 broadcast 192.168.7.255
status: active
zsh: no matches found: /dev/ttybela
