Ok, this is what happens when I run and then stop the patch:
Building project...
Build finished
Running project...
Running Pd 0.48-2
Audio channels in use: 2
Analog channels in use: 8
Digital channels in use: 16
The following MIDI devices are enabled:
Num Name In Out Pd channels
[ 0] hw:1,0,0 x x (1-16)
Adding Midi device: hw:1,0,0
ALSA lib rawmidi_hw.c:233:(snd_rawmidi_hw_open) open /dev/snd/midiC1D0 failed: Device or resource busy
Failed call to __wrap_bind
Error while creating pipe bela-midiOut_hw:1,0,0: Operation not permitted
Failed to open MIDI device hw:1,0,0
bonk version 1.5
fiddle version 1.1 TEST4
pique 0.1 for PD version 23
sigmund~ version 0.07
On port 0 (hw:1,0,0): type: system, channel: 8,
On port 0 (hw:1,0,0): type: note on, channel: 0, data1: 3, data2: 100,
On port 0 (hw:1,0,0): type: note on, channel: 0, data1: 3, data2: 0,
On port 0 (hw:1,0,0): type: note on, channel: 0, data1: 8, data2: 100,
On port 0 (hw:1,0,0): type: note on, channel: 0, data1: 8, data2: 0,
On port 0 (hw:1,0,0): type: note on, channel: 0, data1: 0, data2: 100,
On port 0 (hw:1,0,0): type: note on, channel: 0, data1: 0, data2: 0,
Makefile:524: recipe for target 'runide' failed
make: *** [runide] Terminated
1 mode switch detected on the audio thread!
Bela stopped
root@bela ~/Bela#
