Hello,
I am using the audio expander with bela cape rev B and am trying to measure the time delay between each analog channel per sample. I am using 8 channels at 22050 Hz sampling rate. From this post here it says that channel 0 is sampled first, but from my measurements (connecting all channels together, playing sine sweep, calculating phase shift) it seems that channel 7 is measured first and channel 0 is measured last. Is 7 the first channel to be sampled or am I doing something wrong in my calculations?
Thank you very much!
