Hello,
I have the following setup:
Bela Mini with Multichannel Expander
CyFi Nu Pickup
Both are ideally being powered off the same supply, and the pickup is just monitoring a string and passing that through to the Bela.
I'm also outputting a Sin Wave, although not for direct output to speakers, that's being used in an external op-amp circuit where it's being amplified. However, even though I'm not sending the Sin Wave out to my headphones, I'm still hearing it quite loudly.
The problem goes away if I disconnect the pickup, so I suspect some sort of cross-talk is happening. Any solutions to try and fix this?
Thank you!!
