We never implemented that flag, though we likely will in the next two months, for the release of the new generation of boards. So, a delay line is your best bet. Note that each analog input is sampled at a different time, unlike the audio inputs that are all samples at the same time. This means that you will always have sub-sample phase differences between the analog channels. If your application is sensitive to this type of phase inconsistencies, then the analog inputs may not be the right choice.
