Hi,
I’m new to the forums here, so forgive me if this has been discussed before (I couldn’t find anything relevant by searching)..
Has there been any work/research/tutorials/etc done to illustrate how to best connect multiple Belas together?
“Best” in this case would be some combo of cheapest, easiest, highest bandwidth, lowest latency.
Is OSC over WiFi typically how people manage this? Or are there opportunities to add a wire or two to make things a bit more robust?
The general topology I’m thinking of is, a Bela mini in an instrument, and another BBB Bela living in a pedal (x2 or 3?), with some way to share control data, and ideally also audio buffer data.
Thanks much!
