I'm a first time KiCad user attempting to design a custom trill flex sensor using the trill flex tutorial.
I've installed the trill schematic and footprint libraries.
I'm using KiCad 9.0.5, so some of the features and UI are different than the tutorial instructions.
1) I set corner smoothing to one of the pads with fillet radius 2, but there is no option to export settings to other zones. If I click ok for selected pad, the corners are not rounded. Also none of my pads are green like tutorial.
2) When I try to connect pads to nets, if I click on a single pad there are no 'nets' available in the window that pops up like in the youtube tutorial.
I realize my questions are probably more suited to a KiCad forum but thought I post here since it seems others are having the same issue following the custom flex sensor tutorial.
See screen shots here.
Should I be using an older version on KiCad for this?
