Hi Giulio. I systematically tested Pot 7's signal path, starting from the Eurorack 12V power supply through the voltage selection circuit, jumper configuration (J12), and CV IN 8 jack, and confirmed that 10V was successfully reaching the jack terminals. However, when I measured all three pins on Pot 7 itself, they all read 0V, which told me there was a broken PCB trace or cold solder joint between the jack output and Pot 7's hot pin. I soldered a jumper wire directly from the CV IN 8 jack's 10V terminal to Pot 7 Pin 3, and now the pot reads 10V when turned fully right with varying voltages at the wiper, which definitively confirms the problem in the Pepper board's PCB traces or connections—not a component failure, jumper misconfiguration, or power issue. Could you please let me know if I could send this to have a look ?thank you
edit: I have identified the exact failure point (between jack and R23) and fixed the issue:
- R23 did not receive V. I connected a jumper wire from the jack in 8 to the R23 left pin. Now it's all working. This suggests that the pepper board has a broken PCB trace.
POTS: P0:0.894 P1:0.877 P2:0.890 P3:0.906 P4:0.876 P5:0.885 P6:0.894 P7:0.902
POTS: P0:0.320 P1:0.439 P2:0.000 P3:0.000 P4:0.000 P5:0.000 P6:0.000 P7:0.000
POTS: P0:0.000 P1:0.000 P2:0.000 P3:0.000 P4:0.000 P5:0.000 P6:0.000 P7:0.000
POTS: P0:0.894 P1:0.878 P2:0.889 P3:0.906 P4:0.876 P5:0.884 P6:0.895 P7:0.902
POTS: P0:0.894 P1:0.878 P2:0.891 P3:0.906 P4:0.876 P5:0.884 P6:0.894 P7:0.902
