Hello!
My other BelaMini (yes, I have two), sometimes while I’m using it and it’s working perfectly fine, suddenly starts having a very high latency (more than half a second) and sounds somewhat glitchy. This only happens occasionally, and so far and after many experiments I haven’t found any sure cause-effect relationship that explains what triggers this state.
The only correlation I’ve noticed is that it tends to happen quite often when I unplug and plug back in the jack cable from the audio output. That doesn’t really make much sense to me as a reason for the Bela to start malfunctioning. But statistically, I’ve confirmed that there must be some kind of connection.
Does this make any sense to you?
(The setup consist of a midi controller and midi interface connected to the BelaMini via a USB hub)
Thanks!
