Hi everyone,
I have an older Bela board (the bigger version) and tried to run a project on it that I developed with a newer version of Bela. I updated the board to the dev branch, but when I start it or try to run my PD patch, I get a lot of error messages.
Is my board just too old, or did I do something wrong during the update?
Here’s what the console outputs::
Nov 03 17:17:31 bela stdbuf[959]: main at default_main.cpp:80
Nov 03 17:17:31 bela stdbuf[959]: Segmentation fault
Nov 03 17:17:31 bela stdbuf[959]: Makefile:614: recipe for target 'runonly' failed
Nov 03 17:17:31 bela stdbuf[959]: make: *** [runonly] Error 139
Nov 03 17:17:31 bela stdbuf[959]: make: Leaving directory '/root/Bela'
Nov 03 17:17:31 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Nov 03 17:17:31 bela systemd[1]: bela_startup.service: Unit entered failed state.
Nov 03 17:17:31 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Nov 03 17:17:31 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Nov 03 17:17:31 bela systemd[1]: Stopped Run Bela at boot.
Nov 03 17:17:31 bela systemd[1]: Started Run Bela at boot.
Nov 03 17:17:31 bela stdbuf[996]: make: Entering directory '/root/Bela'
Nov 03 17:17:32 bela stdbuf[996]: make: Warning: File 'libraries/BelaLibpd/build/BelaLibpd.d' has modification time 279313395 s in the future
Nov 03 17:17:32 bela stdbuf[996]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Nov 03 17:17:32 bela stdbuf[996]: gpio/direction: No such file or directory
Nov 03 17:17:32 bela stdbuf[996]: Program crashed with Segmentation Fault. Backtrace:
Nov 03 17:17:33 bela stdbuf[996]: ?? ??:0
Nov 03 17:17:33 bela stdbuf[996]: Gpio::clear() at Gpio.h:50
Nov 03 17:17:33 bela stdbuf[996]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Nov 03 17:17:33 bela stdbuf[996]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Nov 03 17:17:33 bela stdbuf[996]: detectBelaRevC() at board_detect.cpp:74
Nov 03 17:17:33 bela stdbuf[996]: (inlined by) Bela_detectHw at board_detect.cpp:164
Nov 03 17:17:33 bela stdbuf[996]: Bela_detectHw at board_detect.cpp:151
Nov 03 17:17:33 bela stdbuf[996]: Bela_initAudio at RTAudio.cpp:408
Nov 03 17:17:33 bela stdbuf[996]: main at default_main.cpp:80
Nov 03 17:17:33 bela stdbuf[996]: Segmentation fault
Nov 03 17:17:33 bela stdbuf[996]: Makefile:614: recipe for target 'runonly' failed
Nov 03 17:17:33 bela stdbuf[996]: make: *** [runonly] Error 139
Nov 03 17:17:33 bela stdbuf[996]: make: Leaving directory '/root/Bela'
Nov 03 17:17:33 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Nov 03 17:17:33 bela systemd[1]: bela_startup.service: Unit entered failed state.
Nov 03 17:17:33 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:35 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:35 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:35 bela systemd[1]: Started Run Bela at boot.
Sep 10 12:46:35 bela stdbuf[1049]: make: Entering directory '/root/Bela'
Sep 10 12:46:35 bela stdbuf[1049]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Sep 10 12:46:36 bela stdbuf[1049]: gpio/direction: No such file or directory
Sep 10 12:46:36 bela stdbuf[1049]: Program crashed with Segmentation Fault. Backtrace:
Sep 10 12:46:37 bela stdbuf[1049]: ?? ??:0
Sep 10 12:46:37 bela stdbuf[1049]: Gpio::clear() at Gpio.h:50
Sep 10 12:46:37 bela stdbuf[1049]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Sep 10 12:46:37 bela stdbuf[1049]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Sep 10 12:46:37 bela stdbuf[1049]: detectBelaRevC() at board_detect.cpp:74
Sep 10 12:46:37 bela stdbuf[1049]: (inlined by) Bela_detectHw at board_detect.cpp:164
Sep 10 12:46:37 bela stdbuf[1049]: Bela_detectHw at board_detect.cpp:151
Sep 10 12:46:37 bela stdbuf[1049]: Bela_initAudio at RTAudio.cpp:408
Sep 10 12:46:37 bela stdbuf[1049]: main at default_main.cpp:80
Sep 10 12:46:37 bela stdbuf[1049]: Segmentation fault
Sep 10 12:46:37 bela stdbuf[1049]: Makefile:614: recipe for target 'runonly' failed
Sep 10 12:46:37 bela stdbuf[1049]: make: *** [runonly] Error 139
Sep 10 12:46:37 bela stdbuf[1049]: make: Leaving directory '/root/Bela'
Sep 10 12:46:37 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Sep 10 12:46:37 bela systemd[1]: bela_startup.service: Unit entered failed state.
Sep 10 12:46:37 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:37 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:37 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:37 bela systemd[1]: Started Run Bela at boot.
Sep 10 12:46:37 bela stdbuf[1102]: make: Entering directory '/root/Bela'
Sep 10 12:46:37 bela stdbuf[1102]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Sep 10 12:46:37 bela stdbuf[1102]: gpio/direction: No such file or directory
Sep 10 12:46:37 bela stdbuf[1102]: Program crashed with Segmentation Fault. Backtrace:
Sep 10 12:46:38 bela stdbuf[1102]: ?? ??:0
Sep 10 12:46:38 bela stdbuf[1102]: Gpio::clear() at Gpio.h:50
Sep 10 12:46:38 bela stdbuf[1102]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Sep 10 12:46:38 bela stdbuf[1102]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Sep 10 12:46:38 bela stdbuf[1102]: detectBelaRevC() at board_detect.cpp:74
Sep 10 12:46:38 bela stdbuf[1102]: (inlined by) Bela_detectHw at board_detect.cpp:164
Sep 10 12:46:38 bela stdbuf[1102]: Bela_detectHw at board_detect.cpp:151
Sep 10 12:46:38 bela stdbuf[1102]: Bela_initAudio at RTAudio.cpp:408
Sep 10 12:46:38 bela stdbuf[1102]: main at default_main.cpp:80
Sep 10 12:46:38 bela stdbuf[1102]: Segmentation fault
Sep 10 12:46:38 bela stdbuf[1102]: Makefile:614: recipe for target 'runonly' failed
Sep 10 12:46:38 bela stdbuf[1102]: make: *** [runonly] Error 139
Sep 10 12:46:38 bela stdbuf[1102]: make: Leaving directory '/root/Bela'
Sep 10 12:46:38 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Sep 10 12:46:38 bela systemd[1]: bela_startup.service: Unit entered failed state.
Sep 10 12:46:38 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:38 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:38 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:38 bela systemd[1]: Started Run Bela at boot.
Sep 10 12:46:38 bela stdbuf[1137]: make: Entering directory '/root/Bela'
Sep 10 12:46:38 bela stdbuf[1137]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Sep 10 12:46:39 bela stdbuf[1137]: gpio/direction: No such file or directory
Sep 10 12:46:39 bela stdbuf[1137]: Program crashed with Segmentation Fault. Backtrace:
Sep 10 12:46:39 bela stdbuf[1137]: ?? ??:0
Sep 10 12:46:39 bela stdbuf[1137]: Gpio::clear() at Gpio.h:50
Sep 10 12:46:39 bela stdbuf[1137]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Sep 10 12:46:39 bela stdbuf[1137]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Sep 10 12:46:39 bela stdbuf[1137]: detectBelaRevC() at board_detect.cpp:74
Sep 10 12:46:39 bela stdbuf[1137]: (inlined by) Bela_detectHw at board_detect.cpp:164
Sep 10 12:46:39 bela stdbuf[1137]: Bela_detectHw at board_detect.cpp:151
Sep 10 12:46:39 bela stdbuf[1137]: Bela_initAudio at RTAudio.cpp:408
Sep 10 12:46:39 bela stdbuf[1137]: main at default_main.cpp:80
Sep 10 12:46:39 bela stdbuf[1137]: Segmentation fault
Sep 10 12:46:39 bela stdbuf[1137]: Makefile:614: recipe for target 'runonly' failed
Sep 10 12:46:39 bela stdbuf[1137]: make: *** [runonly] Error 139
Sep 10 12:46:39 bela stdbuf[1137]: make: Leaving directory '/root/Bela'
Sep 10 12:46:39 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Sep 10 12:46:39 bela systemd[1]: bela_startup.service: Unit entered failed state.
Sep 10 12:46:39 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:39 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:39 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:39 bela systemd[1]: Started Run Bela at boot.
Sep 10 12:46:39 bela stdbuf[1172]: make: Entering directory '/root/Bela'
Sep 10 12:46:40 bela stdbuf[1172]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Sep 10 12:46:40 bela stdbuf[1172]: gpio/direction: No such file or directory
Sep 10 12:46:40 bela stdbuf[1172]: Program crashed with Segmentation Fault. Backtrace:
Sep 10 12:46:41 bela stdbuf[1172]: ?? ??:0
Sep 10 12:46:41 bela stdbuf[1172]: Gpio::clear() at Gpio.h:50
Sep 10 12:46:41 bela stdbuf[1172]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Sep 10 12:46:41 bela stdbuf[1172]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Sep 10 12:46:41 bela stdbuf[1172]: detectBelaRevC() at board_detect.cpp:74
Sep 10 12:46:41 bela stdbuf[1172]: (inlined by) Bela_detectHw at board_detect.cpp:164
Sep 10 12:46:41 bela stdbuf[1172]: Bela_detectHw at board_detect.cpp:151
Sep 10 12:46:41 bela stdbuf[1172]: Bela_initAudio at RTAudio.cpp:408
Sep 10 12:46:41 bela stdbuf[1172]: main at default_main.cpp:80
Sep 10 12:46:41 bela stdbuf[1172]: Segmentation fault
Sep 10 12:46:41 bela stdbuf[1172]: Makefile:614: recipe for target 'runonly' failed
Sep 10 12:46:41 bela stdbuf[1172]: make: *** [runonly] Error 139
Sep 10 12:46:41 bela stdbuf[1172]: make: Leaving directory '/root/Bela'
Sep 10 12:46:41 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Sep 10 12:46:41 bela systemd[1]: bela_startup.service: Unit entered failed state.
Sep 10 12:46:41 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:42 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:42 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:42 bela systemd[1]: Started Run Bela at boot.
Sep 10 12:46:42 bela stdbuf[1244]: make: Entering directory '/root/Bela'
Sep 10 12:46:42 bela stdbuf[1244]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Sep 10 12:46:42 bela stdbuf[1244]: gpio/direction: No such file or directory
Sep 10 12:46:42 bela stdbuf[1244]: Program crashed with Segmentation Fault. Backtrace:
Sep 10 12:46:43 bela stdbuf[1244]: ?? ??:0
Sep 10 12:46:43 bela stdbuf[1244]: Gpio::clear() at Gpio.h:50
Sep 10 12:46:43 bela stdbuf[1244]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Sep 10 12:46:43 bela stdbuf[1244]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Sep 10 12:46:43 bela stdbuf[1244]: detectBelaRevC() at board_detect.cpp:74
Sep 10 12:46:43 bela stdbuf[1244]: (inlined by) Bela_detectHw at board_detect.cpp:164
Sep 10 12:46:43 bela stdbuf[1244]: Bela_detectHw at board_detect.cpp:151
Sep 10 12:46:43 bela stdbuf[1244]: Bela_initAudio at RTAudio.cpp:408
Sep 10 12:46:43 bela stdbuf[1244]: main at default_main.cpp:80
Sep 10 12:46:43 bela stdbuf[1244]: Segmentation fault
Sep 10 12:46:43 bela stdbuf[1244]: Makefile:614: recipe for target 'runonly' failed
Sep 10 12:46:43 bela stdbuf[1244]: make: *** [runonly] Error 139
Sep 10 12:46:43 bela stdbuf[1244]: make: Leaving directory '/root/Bela'
Sep 10 12:46:43 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Sep 10 12:46:43 bela systemd[1]: bela_startup.service: Unit entered failed state.
Sep 10 12:46:43 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:43 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:43 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:43 bela systemd[1]: Started Run Bela at boot.
Sep 10 12:46:43 bela stdbuf[1278]: make: Entering directory '/root/Bela'
Sep 10 12:46:43 bela stdbuf[1278]: Running /root/Bela/projects/Gitarre_Nano/Gitarre_Nano -p256 -C8 -B16 -N1 -G0 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0
Sep 10 12:46:43 bela stdbuf[1278]: gpio/direction: No such file or directory
Sep 10 12:46:43 bela stdbuf[1278]: Program crashed with Segmentation Fault. Backtrace:
Sep 10 12:46:44 bela stdbuf[1278]: ?? ??:0
Sep 10 12:46:44 bela stdbuf[1278]: Gpio::clear() at Gpio.h:50
Sep 10 12:46:44 bela stdbuf[1278]: (inlined by) Es9080_Codec at Es9080_Codec.cpp:48
Sep 10 12:46:44 bela stdbuf[1278]: Tlv320_Es9080_Codec at Tlv320_Es9080_Codec.cpp:19
Sep 10 12:46:44 bela stdbuf[1278]: detectBelaRevC() at board_detect.cpp:74
Sep 10 12:46:44 bela stdbuf[1278]: (inlined by) Bela_detectHw at board_detect.cpp:164
Sep 10 12:46:44 bela stdbuf[1278]: Bela_detectHw at board_detect.cpp:151
Sep 10 12:46:44 bela stdbuf[1278]: Bela_initAudio at RTAudio.cpp:408
Sep 10 12:46:44 bela stdbuf[1278]: main at default_main.cpp:80
Sep 10 12:46:44 bela stdbuf[1278]: Segmentation fault
Sep 10 12:46:44 bela stdbuf[1278]: Makefile:614: recipe for target 'runonly' failed
Sep 10 12:46:44 bela stdbuf[1278]: make: *** [runonly] Error 139
Sep 10 12:46:44 bela stdbuf[1278]: make: Leaving directory '/root/Bela'
Sep 10 12:46:44 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Sep 10 12:46:44 bela systemd[1]: bela_startup.service: Unit entered failed state.
Sep 10 12:46:44 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
Sep 10 12:46:44 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Sep 10 12:46:44 bela systemd[1]: Stopped Run Bela at boot.
Sep 10 12:46:44 bela systemd[1]: bela_startup.service: Start request repeated too quickly.
Sep 10 12:46:44 bela systemd[1]: Failed to start Run Bela at boot.
Thanks in advance for any advice!
