I'm currently using the provided USB - mini USB cable to connect the bela to my laptop, and testing some supercollider effects. Pure supercollider works great. If I send an output signal from my laptop to the bela (using a 3.5mm - 3.5mm cable) then the signal gets noisy.
I assume this is due to a power supply issue, so I'd like to try using my CIOKS DC7 power supply - I'd still be using the miniUSB port of the Bela to connect to the IDE for now, but I guess I'd be using the CIOKS USB B port to connect to the Bela's USB B port. Is this okay and won't break anything? Is it likely to help?
Thanks in advance!
Jordan
