For whatever reason, I can currently only now access the IDE now through http://192.168.8.2, and only one mac computer but not another with (I believe) an identical configuration.
For some reason, Bela's IP address is listed as 192.168.8.1 in the Network settings, rather than the usual 192.168.7 (or 6).1
If I ping this current address I get (1 packets transmitted, 1 packets received, 0.0% packet loss) but the others return 100% loss as does Bela.local. 192.168.8.2 also returns 0.0% loss, as would be expected.
Prior to this as I was having a terrible time accessing the IDE (due to neither bela.local nor the expected IP addresses working) so I ran the update_board script, but that didn't reset the address or make the board accessible through bela.local despite the script saying that it was connecting through root@bela.local.
I did try setting the IP address to one of the more common IPs manually (192.168.7 (or 6).1 ) but this did not make the IDE accessible from those addresses though I could ping the one I had set it too (however if I set it to 192.168.7.1 I could ping this but not 192.168.7.2 (which is the actual board right?) ...so I can't understand this.
Can someone help me understand what is going on and how this updated itself to this new address?
