So in the Crowd Supply update #6 it was mentioned that the Multi can work directly with PDM microphones.
I've seen some older posts on here where a MEMs microphone was suggested with some additional components, to, presumably turn the signal into "audio" before making it to the (older) Bela. But I guess now you can go directly in with a PDM mic.
So towards that end, I imagine that means something like this:
https://www.adafruit.com/product/3492
Where the PDM mic has a couple passive components, with the I/O still being digital (as far as I can tell).
And NOT something like this:
https://www.sparkfun.com/sparkfun-analog-mems-microphone-breakout-sph8878lr5h-1.html
Which appears to output an actual audio signal.
So with that being said, what is it that one is typically looking for in a PDM mic? I don't see the typical (for microphones) frequency response plots, just SNR and sensitivity, as well as stats like that. Beyond that, I don't really know what differentiates one PDM module to another.
What are some good options for PDM mics to use with the Multi?
