giuliomoro rthorntn Can PB2 GPIO handle say velocity CV?
I am not sure what you mean by that.
Thanks, apologies, I should have provided more detail, I mean, can the GPIO on the PB2 (with PWM) output (with the addition of an external LPF) the 127 discrete values that MIDI velocity CV can generate?
Update: maybe the PB2 doesn't have PWM, or only has 4 PWM, not sure (Gem might be using any PWM pins that there are), the Teensy 4.1 has 35 PWM output pins so I just kinda assumed the PB2 had quite a few.
