Hello, I was trying to run 5v power to Bela mini via the P1.01 and GND pins and just ended up with a Bela that doesn't turn on anymore (the blue light comes on for a second and then nothing). What did I do wrong here?
I am trying at the moment to reflash the SD card (which seems to be corrupted). Assuming I get this working and don't have broken bela what are the best options for turning the power off to the board without causing damage? I find that a bit unclear in the docs (ie. do I need to have a switch that triggers the shutdown process or not?)
