i now did the update from the IDE again (with the zip from the heavy-multi-midi) and the update seems to complete, at least the IDE does not complain and restarts.
however to be really sure i also did the update board script thing you mentioned earlier and there i get the following error:
Checking the board is up and running at root@192.168.7.2...Warning: Permanently added '192.168.7.2' (ECDSA) to the list of known hosts.
done
Updating the Bela core code in root@192.168.7.2:/root/Bela
All the changes to the CORE files in the remote folder /root/Bela will be LOST. The content of these files/folders will be lost:
core include Makefile examples Doxyfile scripts resources pru
Your projects stored in /root/Bela/projects should be safe (and surely you have already backed them up somewhere safe, haven't you?).
Are you sure you want to continue? (y/N) y
Updating Bela core files to remote folder /root/Bela
Stopping Bela...done
Updating files...Updated files: 18 ...done
make: Entering directory '/root/Bela/resources/tools/bela-cape-btn'
gcc bela-cape-btn.c -o bela-cape-btn
make: Leaving directory '/root/Bela/resources/tools/bela-cape-btn'
make: Entering directory '/root/Bela/resources/tools/board_detect'
g++ "../../../core/GPIOcontrol.cpp" -c -I../../../include -o "build/GPIOcontrol.o"
g++ "../../../core/Spi_Codec.cpp" -c -I../../../include -o "build/Spi_Codec.o"
g++ "../../../core/I2c_Codec.cpp" -c -I../../../include -o "build/I2c_Codec.o"
g++ "../../../core/board_detect.cpp" -c -I../../../include -o "build/board_detect.o"
g++ "main.cpp" -c -I../../../include -o "build/main.o"
cc build/GPIOcontrol.o build/Spi_Codec.o build/I2c_Codec.o build/board_detect.o build/main.o -o "board_detect"
build/Spi_Codec.o: In function `Spi_Codec::Spi_Codec(char const*, char const*)':
Spi_Codec.cpp:(.text+0x168): undefined reference to `__cxa_end_cleanup'
build/Spi_Codec.o: In function `Spi_Codec::~Spi_Codec()':
Spi_Codec.cpp:(.text+0x1ee): undefined reference to `operator delete(void*, unsigned int)'
build/Spi_Codec.o: In function `__static_initialization_and_destruction_0(int, int)':
Spi_Codec.cpp:(.text+0xa20): undefined reference to `std::ios_base::Init::Init()'
Spi_Codec.cpp:(.text+0xa50): undefined reference to `std::ios_base::Init::~Init()'
build/Spi_Codec.o: In function `AudioCodec::~AudioCodec()':
Spi_Codec.cpp:(.text._ZN10AudioCodecD0Ev[_ZN10AudioCodecD5Ev]+0x12): undefined reference to `operator delete(void*, unsigned int)'
build/Spi_Codec.o:(.ARM.extab+0x0): undefined reference to `__gxx_personality_v0'
build/Spi_Codec.o:(.ARM.extab+0x1c): undefined reference to `__gxx_personality_v0'
build/Spi_Codec.o:(.data.rel.ro._ZTV10AudioCodec[_ZTV10AudioCodec]+0x10): undefined reference to `__cxa_pure_virtual'
build/Spi_Codec.o:(.data.rel.ro._ZTV10AudioCodec[_ZTV10AudioCodec]+0x14): undefined reference to `__cxa_pure_virtual'
build/Spi_Codec.o:(.data.rel.ro._ZTV10AudioCodec[_ZTV10AudioCodec]+0x18): undefined reference to `__cxa_pure_virtual'
build/Spi_Codec.o:(.data.rel.ro._ZTV10AudioCodec[_ZTV10AudioCodec]+0x1c): undefined reference to `__cxa_pure_virtual'
build/Spi_Codec.o:(.data.rel.ro._ZTV10AudioCodec[_ZTV10AudioCodec]+0x20): undefined reference to `__cxa_pure_virtual'
build/Spi_Codec.o:(.data.rel.ro._ZTV10AudioCodec[_ZTV10AudioCodec]+0x24): more undefined references to `__cxa_pure_virtual' follow
build/Spi_Codec.o:(.data.rel.ro+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
build/Spi_Codec.o:(.data.rel.ro._ZTI10AudioCodec[_ZTI10AudioCodec]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
build/I2c_Codec.o: In function `I2c_Codec::I2c_Codec(int, int)':
I2c_Codec.cpp:(.text+0x72): undefined reference to `__cxa_end_cleanup'
build/I2c_Codec.o: In function `I2c_Codec::~I2c_Codec()':
I2c_Codec.cpp:(.text+0x1144): undefined reference to `operator delete(void*, unsigned int)'
build/I2c_Codec.o: In function `__static_initialization_and_destruction_0(int, int)':
I2c_Codec.cpp:(.text+0x117c): undefined reference to `std::ios_base::Init::Init()'
I2c_Codec.cpp:(.text+0x11ac): undefined reference to `std::ios_base::Init::~Init()'
build/I2c_Codec.o: In function `I2c::initI2C_RW(int, int, int)':
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0x60): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0x6e): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0x7c): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0x8a): undefined reference to `std::ostream::operator<<(std::ostream& (*)(std::ostream&))'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0xba): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0xc8): undefined reference to `std::ostream::operator<<(int)'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0xd6): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0xe4): undefined reference to `std::ostream::operator<<(std::ostream& (*)(std::ostream&))'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0x104): undefined reference to `std::cout'
I2c_Codec.cpp:(.text._ZN3I2c10initI2C_RWEiii[_ZN3I2c10initI2C_RWEiii]+0x10c): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)'
build/I2c_Codec.o: In function `I2c::~I2c()':
I2c_Codec.cpp:(.text._ZN3I2cD0Ev[_ZN3I2cD5Ev]+0x12): undefined reference to `operator delete(void*, unsigned int)'
build/I2c_Codec.o:(.ARM.extab+0x0): undefined reference to `__gxx_personality_v0'
build/I2c_Codec.o:(.ARM.extab+0xfc): undefined reference to `__gxx_personality_v0'
build/I2c_Codec.o:(.data.rel.ro._ZTV3I2c[_ZTV3I2c]+0x8): undefined reference to `__cxa_pure_virtual'
build/I2c_Codec.o:(.data.rel.ro+0x0): undefined reference to `vtable for __cxxabiv1::__vmi_class_type_info'
build/I2c_Codec.o:(.data.rel.ro._ZTI3I2c[_ZTI3I2c]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
build/board_detect.o: In function `split(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char)':
board_detect.cpp:(.text+0xd6): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
board_detect.cpp:(.text+0xe4): undefined reference to `std::__cxx11::basic_istringstream<char, std::char_traits<char>, std::allocator<char> >::basic_istringstream(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::_Ios_Openmode)'
board_detect.cpp:(.text+0xf4): undefined reference to `std::basic_istream<char, std::char_traits<char> >& std::getline<char, std::char_traits<char>, std::allocator<char> >(std::basic_istream<char, std::char_traits<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char)'
board_detect.cpp:(.text+0x104): undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator bool() const'
board_detect.cpp:(.text+0x124): undefined reference to `std::__cxx11::basic_istringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_istringstream()'
board_detect.cpp:(.text+0x12e): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x13a): undefined reference to `std::__cxx11::basic_istringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_istringstream()'
board_detect.cpp:(.text+0x146): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x150): undefined reference to `__cxa_end_cleanup'
build/board_detect.o: In function `trim(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
board_detect.cpp:(.text+0x168): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::empty() const'
board_detect.cpp:(.text+0x176): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
board_detect.cpp:(.text+0x182): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_not_of(char, unsigned int) const'
board_detect.cpp:(.text+0x192): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::length() const'
board_detect.cpp:(.text+0x1a6): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_last_not_of(char, unsigned int) const'
board_detect.cpp:(.text+0x1ba): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned int, unsigned int) const'
build/board_detect.o: In function `parse_belaconfig()':
board_detect.cpp:(.text+0x1f8): undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::basic_ifstream()'
board_detect.cpp:(.text+0x202): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()'
board_detect.cpp:(.text+0x212): undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::open(char const*, std::_Ios_Openmode)'
board_detect.cpp:(.text+0x21e): undefined reference to `std::basic_ios<char, std::char_traits<char> >::fail() const'
board_detect.cpp:(.text+0x23a): undefined reference to `std::basic_istream<char, std::char_traits<char> >& std::getline<char, std::char_traits<char>, std::allocator<char> >(std::basic_istream<char, std::char_traits<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)'
board_detect.cpp:(.text+0x24a): undefined reference to `std::basic_ios<char, std::char_traits<char> >::operator bool() const'
board_detect.cpp:(.text+0x2b8): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x332): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::c_str() const'
board_detect.cpp:(.text+0x34c): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x37e): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x388): undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::~basic_ifstream()'
board_detect.cpp:(.text+0x398): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x3a4): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x3be): undefined reference to `__cxa_begin_catch'
board_detect.cpp:(.text+0x3c6): undefined reference to `__cxa_end_catch'
board_detect.cpp:(.text+0x3d2): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
board_detect.cpp:(.text+0x3dc): undefined reference to `std::basic_ifstream<char, std::char_traits<char> >::~basic_ifstream()'
board_detect.cpp:(.text+0x3e0): undefined reference to `__cxa_end_cleanup'
build/board_detect.o: In function `__static_initialization_and_destruction_0(int, int)':
board_detect.cpp:(.text+0x470): undefined reference to `std::ios_base::Init::Init()'
board_detect.cpp:(.text+0x4a0): undefined reference to `std::ios_base::Init::~Init()'
build/board_detect.o:(.ARM.extab+0xc): undefined reference to `__gxx_personality_v0'
build/board_detect.o:(.ARM.extab+0x38): undefined reference to `__gxx_personality_v0'
build/board_detect.o:(.ARM.extab.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EEC2Ev[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EEC5Ev]+0x0): undefined reference to `__gxx_personality_v0'
build/board_detect.o:(.ARM.extab.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EED2Ev[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EED5Ev]+0x0): undefined reference to `__gxx_personality_v0'
build/board_detect.o: In function `bool std::operator==<char, std::char_traits<char>, std::allocator<char> >(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*)':
board_detect.cpp:(.text._ZSteqIcSt11char_traitsIcESaIcEEbRKNSt7__cxx1112basic_stringIT_T0_T1_EEPKS5_[_ZSteqIcSt11char_traitsIcESaIcEEbRKNSt7__cxx1112basic_stringIT_T0_T1_EEPKS5_]+0xe): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(char const*) const'
build/board_detect.o:(.ARM.extab.text._ZNSt12_Vector_baseINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EED2Ev[_ZNSt12_Vector_baseINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EED5Ev]+0x0): undefined reference to `__gxx_personality_v0'
build/board_detect.o: In function `void std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::_M_emplace_back_aux<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
board_detect.cpp:(.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_]+0xe2): undefined reference to `__cxa_begin_catch'
board_detect.cpp:(.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_]+0x12a): undefined reference to `__cxa_rethrow'
board_detect.cpp:(.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_]+0x12e): undefined reference to `__cxa_end_catch'
board_detect.cpp:(.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_]+0x132): undefined reference to `__cxa_end_cleanup'
build/board_detect.o:(.ARM.extab.text._ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_[_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE19_M_emplace_back_auxIJRKS5_EEEvDpOT_]+0x0): undefined reference to `__gxx_personality_v0'
build/board_detect.o: In function `void __gnu_cxx::new_allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >::construct<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
board_detect.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE9constructIS6_JRKS6_EEEvPT_DpOT0_[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE9constructIS6_JRKS6_EEEvPT_DpOT0_]+0x28): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
board_detect.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE9constructIS6_JRKS6_EEEvPT_DpOT0_[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE9constructIS6_JRKS6_EEEvPT_DpOT0_]+0x36): undefined reference to `__cxa_end_cleanup'
build/board_detect.o:(.ARM.extab.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE9constructIS6_JRKS6_EEEvPT_DpOT0_[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE9constructIS6_JRKS6_EEEvPT_DpOT0_]+0x0): undefined reference to `__gxx_personality_v0'
build/board_detect.o: In function `std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::_M_check_len(unsigned int, char const*) const':
board_detect.cpp:(.text._ZNKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE12_M_check_lenEjPKc[_ZNKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EE12_M_check_lenEjPKc]+0x32): undefined reference to `std::__throw_length_error(char const*)'
build/board_detect.o: In function `void __gnu_cxx::new_allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >::destroy<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
board_detect.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE7destroyIS6_EEvPT_[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE7destroyIS6_EEvPT_]+0xc): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
build/board_detect.o: In function `__gnu_cxx::new_allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >::deallocate(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, unsigned int)':
board_detect.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE10deallocateEPS6_j[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE10deallocateEPS6_j]+0xe): undefined reference to `operator delete(void*)'
build/board_detect.o: In function `void std::_Destroy<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
board_detect.cpp:(.text._ZSt8_DestroyINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEEvPT_[_ZSt8_DestroyINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEEvPT_]+0xa): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()'
build/board_detect.o: In function `__gnu_cxx::new_allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >::allocate(unsigned int, void const*)':
board_detect.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE8allocateEjPKv[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE8allocateEjPKv]+0x24): undefined reference to `std::__throw_bad_alloc()'
board_detect.cpp:(.text._ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE8allocateEjPKv[_ZN9__gnu_cxx13new_allocatorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEE8allocateEjPKv]+0x32): undefined reference to `operator new(unsigned int)'
build/board_detect.o: In function `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*>, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*>(std::move_iterator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*>, std::move_iterator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*>, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*)':
board_detect.cpp:(.text._ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_[_ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_]+0x5c): undefined reference to `__cxa_begin_catch'
board_detect.cpp:(.text._ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_[_ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_]+0x68): undefined reference to `__cxa_rethrow'
board_detect.cpp:(.text._ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_[_ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_]+0x6c): undefined reference to `__cxa_end_catch'
board_detect.cpp:(.text._ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_[_ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_]+0x70): undefined reference to `__cxa_end_cleanup'
build/board_detect.o:(.ARM.extab.text._ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_[_ZNSt20__uninitialized_copyILb0EE13__uninit_copyISt13move_iteratorIPNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEES9_EET0_T_SC_SB_]+0x0): undefined reference to `__gxx_personality_v0'
build/board_detect.o: In function `void std::_Construct<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)':
board_detect.cpp:(.text._ZSt10_ConstructINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEJS5_EEvPT_DpOT0_[_ZSt10_ConstructINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEJS5_EEvPT_DpOT0_]+0x26): undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&)'
Makefile:10: recipe for target 'board_detect' failed
make: *** [board_detect] Error 1
make: Leaving directory '/root/Bela/resources/tools/board_detect'
An error occurred.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
so i am now not sure, the bela core was really updated :-(
