Thank you for a quick response.
Where would you suggest to perform the digital read - as far as I understand, the render function is called for each frame block, and from what I can see the lowest block size I can select is two frames pr. block, causing me to get a call frequency of the render function of 44.1kHz/2 = 22.05kHz -> 44 ms
On another note, I am really looking forward to the Bela Gem. I have bought a couple of Pocketbeagle 2 for testing purposes, would it be possible to start testing the Bela software on the these before the release of the the Gem?
Best,
Simon
