Grumpy_Mike So if I have then what do I do to uninstall it?
I think I solved that, there is a section on https://www.joshuawise.com about un-installing it says:-
"If, for some reason, you need to uninstall HoRNDIS, you can simply drag the extension to the trash. In the Finder, go to the “Go” menu, and select “Go to folder...”; in that, type “/System/Library/Extensions”. Find “HoRNDIS.kext”, and drag it to the trash. When prompted, type your password. Do the same for the “HoRNDIS.kext” that lives in “/Library/Extensions”, as well. Then, restart your Mac to be sure it is unloaded."
I did not find HoRNDIS.kex in the /System/Library/Extensions but I did find it in the /Library/Extensions. So I rebooted my iMac. I could also see a serial port called "/dev/cu.usbmodembela6" but there are no examples or mention of any libraries on my system.
My conclusion is that software from Joshua Wise is still being blocked, as per the initial request.
