Ray02 Hello Bela friends! I have a problem with a patch that i'm creating: on my laptop is working fine, also after several our, when i put the patch on the bela after some second it start to create a distorsion like if some thing if frying. Can some one help me to understand why is doing this? here the patch https://www.dropbox.com/sh/0swu5vlfv09dx7a/AABTRQge9LtvrlNPx05dpzh2a?dl=0 thanks for the help
giuliomoro I tried it for a few minutes and it seems ok except for the occasional dropped block ( you can run at higher blocksizes to fix that). Can you record it when it happens? Do you see anything on the Bela console when you hear the distortion? Does the CPU usage increase?
Ray02 Ah! i'm very happy to see that you are rigth! today after long time i update the bela, and may be this fix some problem that i had on this project. thanks for the time and the help!
