I'm working with a Bela Mini for the first time and am designing a PCB to mount it on. I'm hoping to power it directly from the PCB (which will in turn be connected to an external power supply). Reading this page it seems like that should work. However, I'm not clear on which pin is P1.01 on the top of the Bela. It's not indicated on the pin diagram, and though I see it on the Beaglebone I'm not sure if that connects vertically straight through. I also see that there is a LiPo Vin, but I'm not sure if I can use that for a wall power supply.
Any advice for how to do the power would be very appreciated 🙂
EDIT: Looking at the Bela Mini KiCad footprint I'm quite sure the top left pin (in the pin diagram) is also Vin on the Mini. But I would still appreciate confirmation before connecting power there.
