Hi,
I'm walking my first steps with bela and audio expander capelet, still a bit lost into documentation!
How can I send 4 audio signals (16b 44.1k) with pure data to audio expander outputs : should i use [dac~ 3], [dac~ 4], etc.?
Hi,
you need to set the settings in the IDE to use 4 analog channels at 44.1kHz; then you will send to them with [dac~ 3 4 5 6 ]
Thanks, it's much clearer. I set the 4 analog channels and selected audio expander as active in the IDE capelet settings and checked outputs 0, 1, 2, 3. But, I'm not sure of this last item?
yes that's correct. Enabling the channels in the capelet settings allows you to select which ones you want to be handled as audio signals and which one should be treated as "regular analog".
ok, thanks for your help
