Hi,
After I uploaded a wrong - unfinished - Pure Data Patch and Bela got stuck in a reboot loop.
I followed your advice and made a patch that uses arrays to play sound instead of writing to disk --> Arrays of of 5 seconds to record and then play them.
Everything works ok (latency) if I use [key] on my computer to record from microphone and play the file with another [key].
I then replaced key with the mpr121 code and all hell broke loose.
No idea if the Pure Data Patch is related to the Eternal disconnect - but we are causal creatures, so I presume it's linked?
Here are the error messages - no time to select them, so I made screenshots.
The finished not uploaded patch:
I will now reflash the image if it's possible :-/
Like we say in French - ce n'est pas gagné!
