Great! Sorry I didn't spot the P2_15/16 mistake earlier. I split this out to a dedicated thread.
Ok, its done....
so what we have is:
- 8 CV input
- 2 audio/cv outputs
- based on Bela Mini, so A8 1ghz, low latency
- fits in AE Module , 2U module (5x10x3cm!)
it was a very tight squeeze as I wanted it to fit into 2U , even the bela sticker I had just had to be trimmed 🙂
Trying to cram 8 voltage dividers, and a mcp 6002 with 4 resistors and 2 headers, on a 5x3 cm board, challenged my (not great soldering skills) , but just about possible to do as i used a double sided protoboard.
it could quite easily be extended to have some digital IO (5v) ... and Id like probably add some LEDs as well.
probably could be squeezed in a 1U 'expander'.
that said, If I was doing again (or if I do the expander), I might be tempted to go to 4U, as just help space things out a bit ...
(if anyone else plans on doing, unless you plan to get PCBs made up, or are good at soldering id recommend 3U/4U, and save pulling out your hair!)
anyway heres some pics
7 days later
hi @giuliomoro et al 🙂
so Ive noticed Ive got a slight high pitched noise coming thru...
(didnt notice previously, as i had a LP filter following it 😉 )
in the following plots,
the top one is belamini generating a 440hz sine connected to the scope. (powered via usb, or gpio i see the same)
the bottom, I disconnected belamini and instead generated the sine from the wavegenerator (so testing my circuit, in isolation to bela)
(Im using an analog discovery 2, so it can provide power/wave generator and scoping - nice device 🙂 )
the noise looks similar, but you can see some repeating peaks, a ~3khz intervals,
which im guessing is what i can hear. even though it looks pretty quiet (-60db) in the plots, compare to the main signal ~0db), but given nothing else on FFT, its all I can think it is.
is this some kind of switching noise?
I disabled the LEDs, as mentioned in another but made no difference.
I was very tight on space on the protoboard, so left off capacitors to see if it 'would do', so half expected this 😉
just wondering if there is a simple solution?
im wondering in particular is it some kind of noise coming from powering the op-amp from the same supply as bela?
Ive sometimes seen a capacitor put in between the supply (5v) to ground, would this help? what kind of value?
note: (for completeness, and in case its part of the issue)
i used 3.3k / 4.7kohm resistors for the opamp, to get the gain i need (1+3.3k/4.7k) as its what I had, that were close enough ... without using a series of resistors, which ... you guess it, i didnt have space for 😉
a month later
ok, so I had a bit more time to look at this...
so it appears the issue is purely down to powering the Belamini from the AE module power lines.
basically what happens is, even with just the belamini connected, (not my circuit), other modules start having noise on their outputs - particularly noticeable as belamini starts, but then turns into a high pitch sound later.
before I started, I kind of expected this, as id heard the switching of microprocessors does this, but it appeared ok.. however, Ive now found thats was because I used modules on a separate power line /ribbon 😉 (so faulty testing)
so the question is....
the BelaMini needs 5v, and I have 5v on the ribbon, what do I do, to stop the belamini 'polluting' the power line?
Is this the role of a voltage regulator? or a large capacitor? (to smooth out the load requirements of the belamini?)
( I tried to look at some other schematics e.g. mutable clouds, but they use a regulator to drop the voltage from 12v to 3.3v, which is not what i need.... but wondering if this is also doing the 'stabilising' !?)
Can someone point me to a simple solution/schematic... and if its a voltage regulator/cap, which model/specs?
(Im preferably after something really simple given my skill set, or lack of 😉 )
    The BelaMini probably draws about 420mA, how much spare current can the AE modular power supply provide? If you are exceeding the PSU's limits, then this normally translates in the provided voltage being saggy and noisy, in turn affecting the audio and CV I/Os.
    I am not familiar with the topology of the AE, but is there any way you could get the 5V for the ribbon that goes to Bela from a stand-alone 1A PSU (e.g.: a mobile phone charger?). That'd be a matter of breaking out the 5V and GND wires from the PSU, connect the GND to the power GND of the AE, but connect the 5V to the BelaMini input only.
    thetechnobear however, Ive now found thats was because I used modules on a separate power line /ribbon 😉 (so faulty testing)
    not sure what you mean by this.
    power supply is 9v 1.3a, and there is not much current draw from the modules, so I think this should be ok.
    'separate power line/ribbon' , so the AE modular, has a master module, which takes the 9v PSU and then (among other things), has two ribbons from it, one feeding top row, the other the bottom row - so the noise only appears on the same row as the bela mini is on.
    I could possibly power it separately but that's not ideal (but I do mean to do this as a test anyway) as two things to plug in... though if powered from the usb, then this obviously is useful for programming too.
    this means drilling the case, and also 'fixing' the module position - not really a big deal.
    (unless I do like salt, and get a small extender to put on the front panel)
    another option, would be to look to take the power supply from the 9v supply already present, and the put thru a regulator down to 5v but again this kind of fixes the modules position, and is a bit more complex.
    Ive asked Robert, and he thinks perhaps an inductor , which also someone on the muffwiggler forum thought too, but the size of this needs to be calculated.
    @giuliomoro, do you know how this was done for Salt? was there a similar issue?
    ( unfortunately terminal tedium (rPI eurorack) don't have a schematic so not sure how they solved the issue)
    small update: (more info)
    so I tried powering the belamini from usb (just taking gnd to make it common) , and viola the noise goes away.
    so definitely power related.
    I had a quick look at the terminal tedium, which i think is similarly taking 5v from eurorack to supply a rPI3, and whilst i cannot find the schematic(!) , I can see on the BOM they use an 10uH inductor (mouser #542-78F100-RC), but without the schematic I cant see how its connected, or if its used in conjunction with something else (capacitor) - or 100% confirm it is using the 5v supply (but does look like it)
      thetechnobear another option, would be to look to take the power supply from the 9v supply already present, and the put thru a regulator down to 5v but again this kind of fixes the modules position, and is a bit more complex.
      On Salt we use this to DC-DC convert the +12V rail to +5V.
      We could have used the +5V rail, but normally PSUs don't provide much current on the +5V rail. We could have used a linear regulator (e.g.: LM7805), but it tends to heat up a lot (500mA with a voltage drop of 7V is 3.5W), which is not so good for enclosed environments (although LM7805 are indeed used on some PSUs to generate the +5V rail).
      In your case you have a 4V drop (from 9V to 5V), so that would be about 2W on the LM7805, which could be more manageable. If you go this way, make sure you put a reasonably sized heatsink on it (check the datasheet for the required dissipation characteristics of the heatsink).
      If you were to try with the inductor, that should go in series with the 5V rail before it hits the Bela Mini. You may also want to add a capacitor in there if needed. Check, e.g.: chapter 5 here.
      thetechnobear so I tried powering the belamini from usb (just taking gnd to make it common) , and viola the noise goes away.
      That's great. To double check you are not pushing the limits of the PSU, I'd also try to replace BelaMini with an equivalent 10ohm resistance (e.g.: R = 5V/0.5A = 10ohm), get at least a 2W resistor (or many lower-rated ones in parallel, e.g.: 16 1/8W resistors in parallel). Power the modular up with this dummy load and make sure the other modules have no degradation in the performance. This wouldn't necessarily be the same noise that you'd get when BelaMini is powered (because that would also be modulated by the current usage of BelaMini), but you may find weird interactions between LEDs and CVs, weirdness in the tunings, etc.
      thetechnobear (unless I do like salt, and get a small extender to put on the front panel)
      You'll find a number of ready-made micro-USB male to panel-mount USB-B on Amazon. We couldn't use them on Salt because of space constrains, but you may be luckier.
        wow, thanks giuliomoro thats a ton of information... a bit overwhelming of first glance, but definitely the answers are in there 🙂
        I'll also take a look at the micro-usb adapter... this could be pretty handy for patch upload as well.
        hmm, much to muse over, didn't realise the power noise side has so many sides to it, goes to show what a great job you've done on Salt!
        @thetechnobear just curious about one thing in your report. Does the high pitch change if you stop the audio calculations? I mean if there is no software running? or is it the same?
          Hypasus thats a good question!
          it seems to be the same pitch BUT ive not tested with a patch that changes calculations constantly.
          Ive a suspicion, it would change, since the pitch changes as BelaMini is booting.
          Ive yet to decide what to do... partly as Im finding it complex to get a idea what values to use for the inductor and capacitor, which increasingly look like the 'correct' solution (or at least without hacking AEM master module)
          Robert at TangibleWaves/AEM, has said he will do a bit of research, but his very busy producing modules at the moment, as AEM has been selling well recently - which is good news!
          (id hoped there would be just a general rule of thumb, kind of grab a 10uH inductor and a 1uF, and see if that helps - but having read the great article posted by giuliomoro, Ive realised its more complicated than that 🙂 )
          I looked at the usb front panel adapter, I suspect they will be a bit deep, which probably would mean putting it on the side of the case. also it would mean I need to have USB plugged in to use the module at all, which is not ideal (ok, for dev, but not for just using the module 'standalone')
